I have many ESP8266 works as stations connected to router which sees them as ESP8266F, ESP_1354B8, ESP_8077E4, etc.
Is it possible, to change name of ESP8266 seen through router?
Regards!
Explore... Chat... Share...
wifi_station_set_hostname("your hostname")Dondu wrote:Thank you fo answer.
I'm not using SDK. There is no AT command to do it, isn't it?
If wifi_station_set_hostname make it permanent or only to turnoff power?
