#include <ESP8266WebServer.h>
#include "./DNSServer.h"
#include <SPI.h>
#include <SD.h>
const byte DNS_PORT = 53; // Capture DNS requests on port 53
IPAddress apIP(10, 10, 10, 1); // Private network for server
DNSServer dnsServer; // Create the DNS object
ESP8266WebServer server(80);
String responseHTML = ""
"<html><head><title>Captive Portal Test</title>"
"<style>html,body{margin:0;height:100%;overflow:hidden;}"
"img{ min-height:100%; min-width:100%;height:auto;width:auto;"
"position:absolute;top:-100%; bottom:-100%;left:-100%; right:-100%;"
"margin:auto;}</style></head><body><img src='test.png' /><h1>TEST</h1></body></html>";
static bool hasSD = false;
File uploadFile;
void returnOK() {
server.send(200, "text/plain", "");
void returnFail(String msg) {
server.send(500, "text/plain", msg + "\r\n");
bool loadFromSdCard(String path) {
String dataType = "text/plain";
if (path.endsWith("/")) path += "index.htm";
if (path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
else if (path.endsWith(".htm")) dataType = "text/html";
else if (path.endsWith(".css")) dataType = "text/css";
else if (path.endsWith(".js")) dataType = "application/javascript";
else if (path.endsWith(".png")) dataType = "image/png";
else if (path.endsWith(".gif")) dataType = "image/gif";
else if (path.endsWith(".jpg")) dataType = "image/jpeg";
else if (path.endsWith(".ico")) dataType = "image/x-icon";
else if (path.endsWith(".xml")) dataType = "text/xml";
else if (path.endsWith(".pdf")) dataType = "application/pdf";
else if (path.endsWith(".zip")) dataType = "application/zip";
File dataFile = SD.open(path.c_str());
if (dataFile.isDirectory()) {
path += "/index.htm";
if (!dataFile)
return false;
if (server.hasArg("download")) dataType = "application/octet-stream";
if (server.streamFile(dataFile, dataType) != dataFile.size()) {
dataFile.close();
return true;
void handleNotFound() {
if (hasSD && loadFromSdCard(server.uri())) return;
String message = "SDCARD Not Detected\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i = 0; i < server.args(); i++) {
message += " NAME:" + server.argName(i) + "\n VALUE:" + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup(void) {
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP("TEST AP");
dnsServer.start(DNS_PORT, "*", apIP);
//PROBLEM HERE/
server.onNotFound([]() {
server.send(200, "text/html", responseHTML);
server.begin();
if (SD.begin(SS)) {
hasSD = true;
void loop(void) {
dnsServer.processNextRequest();
server.handleClient();
}This code replies the "responseHTML" as a Captive portal page which immediately pop-ups when I connect to the AP:
});The void handleNotFound() handles the page/file request from the browser but if I use it on
server.onNotFound(handleNotFound);the captive portal won't show but if I type the server address 10.10.10.1, the page will appear. What seems to be the problem?
