But this works fine for 2 leds and fan controller. Now wat to do to control six led/lights and fan?
wifi.setmode(wifi.STATION)
wifi.sta.config("SSID","Password")
print(wifi.sta.getip())
--led3 = 5
dim=0
led1 = 5
led2 = 6
led3 = 7
led4 = 4
led5 = 8
led6 = 12
outpin=1
gpio.mode(led1,gpio.OUTPUT)
gpio.write(led1,gpio.LOW)
gpio.mode(led2,gpio.OUTPUT)
gpio.write(led2,gpio.LOW)
gpio.mode(led3,gpio.OUTPUT)
gpio.write(led3,gpio.LOW)
gpio.mode(led4,gpio.OUTPUT)
gpio.write(led4,gpio.LOW)
gpio.mode(led5,gpio.OUTPUT)
gpio.write(led5,gpio.LOW)
gpio.mode(led6,gpio.OUTPUT)
gpio.write(led6,gpio.LOW)
gpio.mode(outpin,gpio.OUTPUT)
gpio.write(outpin,gpio.LOW)
inpin=2
gpio.mode(inpin,gpio.INT,gpio.PULLUP)
function zero_cross()
dt=((100-dim)*76)
tmr.delay(dt)
gpio.write(outpin,gpio.HIGH)
tmr.delay(150)
tmr.wdclr()
return "ON"
function zero_cross1()
dt1=((77-dim)*76)
tmr.delay(dt1)
tmr.delay(150)
tmr.wdclr()
return "ON"
function zero_cross2()
dt2=((60-dim)*76)
tmr.delay(dt2)
tmr.delay(150)
tmr.wdclr()
return "ON"
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive", function(client,request)
local buf = "";
local _, _, method, path, vars = string.find(request, "([A-Z]+) (.+)?(.+) HTTP");
if(method == nil)then
_, _, method, path = string.find(request, "([A-Z]+) (.+) HTTP");
local _GET = {}
if (vars ~= nil)then
for k, v in string.gmatch(vars, "(%w+)=(%w+)&*") do
_GET[k] = v
buf = buf.."<h1> ESP8266 Web Server</h1>";
buf = buf.."<p>GPIO5 <a href=\"?pin=LOW\"><button>LOW</button></a> <a href=\"?pin=MEDIUM\"><button>MEDIUM</button></a></p>";
buf = buf.."<p>GPIO5 <a href=\"?pin=HIGH\"><button>HIGH</button></a> <a href=\"?pin=OFF\"><button>OFF</button></a></p>";
buf = buf.."<p>GPIO14 <a href=\"?pin=ON1\"><button>ON1</button></a> <a href=\"?pin=OFF1\"><button>OFF1</button></a></p>";
buf = buf.."<p>GPIO12 <a href=\"?pin=ON2\"><button>ON2</button></a> <a href=\"?pin=OFF2\"><button>OFF2</button></a></p>";
buf = buf.."<p>GPIO13 <a href=\"?pin=ON3\"><button>ON3</button></a> <a href=\"?pin=OFF3\"><button>OFF3</button></a></p>";
buf = buf.."<p>GPIO2 <a href=\"?pin=ON4\"><button>ON2</button></a> <a href=\"?pin=OFF4\"><button>OFF4</button></a></p>";
buf = buf.."<p>GPIO15 <a href=\"?pin=ON5\"><button>ON2</button></a> <a href=\"?pin=OFF5\"><button>OFF5</button></a></p>";
buf = buf.."<p>GPIO10 <a href=\"?pin=ON6\"><button>ON2</button></a> <a href=\"?pin=OFF6\"><button>OFF6</button></a></p>";
local _on,_off = "",""
if(_GET.pin == "LOW")then
gpio.trig(inpin,"up",zero_cross)
elseif(_GET.pin == "MEDIUM")then
gpio.trig(inpin,"up",zero_cross1)
elseif(_GET.pin == "HIGH")then
gpio.trig(inpin,"up",zero_cross2)
elseif(_GET.pin == "OFF")then
gpio.trig(inpin,"none",zero_cross2)
elseif(_GET.pin == "ON1")then
gpio.write(led1, gpio.HIGH);
elseif(_GET.pin == "OFF1")then
elseif(_GET.pin == "ON2")then
gpio.write(led2, gpio.HIGH);
elseif(_GET.pin == "OFF2")then
elseif(_GET.pin == "ON3")then
gpio.write(led3, gpio.HIGH);
elseif(_GET.pin == "OFF3")then
elseif(_GET.pin == "ON4")then
gpio.write(led4, gpio.HIGH);
elseif(_GET.pin == "OFF4")then
elseif(_GET.pin == "ON5")then
gpio.write(led5, gpio.HIGH);
elseif(_GET.pin == "OFF5")then
elseif(_GET.pin == "ON6")then
gpio.write(led6, gpio.HIGH);
elseif(_GET.pin == "OFF6")then
client:send(buf);
client:close();
collectgarbage();
end)
end)
