But the issue is single-pole light switch.
1) I have to always supply to Transformer 120V
2) When relay disconnect the light still will be on (flowing through transformer)
Any idea how to resolve it?
Explore... Chat... Share...
What kind of load?Led bulb light, for example:
Where does the WiFi switch get it's power from?
Describe the situation better and I can give you a better answer.
