Is it possible to connect ESP via pressing the access point button instead of using a password in the code?
Thanks
Peter
Explore... Chat... Share...
wifi_wps_enable(WPS_TYPE_PBC);
wifi_set_wps_cb(wps_callback());
wifi_wps_start();
WiFi.mode(WIFI_STA);
WiFi.begin("","");
// Check if WiFi is already connected and if not, begin the WPS process.
if (WiFi.status() != WL_CONNECTED) {
Serial.println("\nAttempting connection ...");
WiFi.beginWPSConfig();
do {
Serial.print(".");
} while (WiFi.status != WL_CONNECTED)
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Connected!");
Serial.println(WiFi.SSID());
Serial.println(WiFi.macAddress());
else {
Serial.println("\nConnection already established.");
do {
Serial.print(".");
} while (WiFi.status() != WL_CONNECTED);It takes about 20-25 seconds for home assistant c[…]
