Connection to WiFi network without password
PostPosted: Tue Feb 14, 2017 4:13 am
by Peter1234
In the code always the network ID and password is required. If this changes all hardware projects have to updated.
Is it possible to connect ESP via pressing the access point button instead of using a password in the code?
Thanks
Peter
Re: Connection to WiFi network without password
PostPosted: Thu Feb 16, 2017 9:18 am
by Affix
Hey Peter,
You could make use of the Native SDK WPS Features (Arduino also Has WiFi.WPS)
NativeSDK
Enable WPS Push Button Connect with
Code: Select allwifi_wps_enable(WPS_TYPE_PBC);
WPS Register Callback
Code: Select allwifi_set_wps_cb(wps_callback());
Start WPS
Code: Select allwifi_wps_start();
Make sure you write a callback function to do what you need
Arduino
  WiFi.mode(WIFI_STA);
  WiFi.begin("","");
  // Check if WiFi is already connected and if not, begin the WPS process.
  if (WiFi.status() != WL_CONNECTED) {
      Serial.println("\nAttempting connection ...");
      WiFi.beginWPSConfig();
      do {
      } while (WiFi.status != WL_CONNECTED)
      if (WiFi.status() == WL_CONNECTED) {
        Serial.println("Connected!");
        Serial.println(WiFi.SSID());
        Serial.println(WiFi.macAddress());
  else {
    Serial.println("\nConnection already established.");
PostPosted: Tue Apr 25, 2017 1:25 am
by Peter1234
Thank you, it works.
Only needed to correct two typos:
Code: Select alldo {
    } while (WiFi.status() != WL_CONNECTED);
