By FabioLG
#62649 Hello, I am using the ESP8266-01 with the Arduino MEGA, initially it was working normal, it sent the AT commands without problems.
After disconnecting, I can'it no longer send the AT commands correctly, I tried to reset using the rst pin but I think it did not work, the module is still connected to my router,
When I sending a command the answer looks like this: [00] [00] [00] [00] ...
Suggestions?
Thanks!
