I'm having a peculiar problem. When the ESP8266 sends the HTML code back to the remote browser, it drops lines. If I right click in the browser and look at the source for the HTML, sometimes lines are missing. The trigger seems to be when my HTML code gets to a about 25 lines total, including HTML header and body.
I'm initializing the Arduino/ESP8266 via Putty. I've put some debugging into Putty so that when I open the web browser, it also spits the HTML code into the Putty terminal window. The text that I see in the terminal window is also missing the same lines that are missing in the HTML page. Therefore the problem exists even before the HTML code is broadcast to the remote browser, somehow the Arduino/ESP8266 is getting it wrong to begin with.
If I remove just a couple of lines of code, all works fine, all around. I just can't add enough code to reach my application goal without suffering from this error.
Any ideas?
thanks!
Steve
