Didn't find too much on this, can you guys help me with some suggestions regarding that? Thank you!
Explore... Chat... Share...
WiFiManager wifiManager;
wifiManager.setSTAStaticIPConfig(ip, gateway, subnet);
//starts an access point with the specified name
//here "AutoConnectAP" with password "password"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
Serial.println(F("failed to connect, we should reset as see if it connects"));
delay(3000);
ESP.reset();
delay(5000);
