Module: Generic ESP8266 Module
Flash Size: 512k
CPU Frequency: 80Mhz
Flash Mode: Dio
Flash Frequency: 40Mhz
Upload Using: SERIAL
Reset Method: ck
Here's my sketch:
#include<ESP8266WiFi.h>
#define SS_PIN 4
#define RST_PIN 5
#define host http://smartlbus.esy.es/
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
static const int RXPin = 0, TXPin = 16;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin);
Serial.begin(9600); // Initialize serial communications with the PC
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
WiFi.mode(WIFI_STA);
WiFi.begin("smartbus","qwerty123");
if(WiFi.status()==WL_CONNECTED) Serial.println("Connected to wifi");
WiFiClient client;
const int httpPort = 8000;
if (client.connect("http://www.smartlbus.esy.es", httpPort)) {
Serial.println("Connected to server");
while (ss.available() > 0)
if (gps.encode(ss.read()))
double lat,lng;
float speed;
if (gps.location.isValid())
lat=gps.location.lat();
lng=gps.location.lng();
speed=gps.speed.value();
String data = "lat1=" + (String) lat + "&lng1=" + (String)lng + "&speed=" + (String)speed;
client.println("POST /add.php HTTP/1.1");
client.println("Host: www.smartlbus.esy.es");
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(data.length());
client.println();
client.print(data);
else{
Serial.println("Cannot cannect to server..");
// Look for new cards
Please help me out.
