By 556duckvader
#63320 I some code that I am trying to used on an ESP8266 and I am having some issues with the interrupt timers and I don't know how to fix it. Below is the code that I am using to gather wind speed and direction. If someone would be kind enough to take a look and see what might the issue is that would be great.
Code: Select all#include "TimerOne.h"          // Timer Interrupt set to 2 second for read sensors
#include <math.h>
#define WindSensorPin (14)      // The pin location of the anemometer sensor
// NOT Connected Yet #define WindVanePin (A4)       // The pin the wind vane sensor is connected to
#define VaneOffset 0;        // define the anemometer offset from magnetic north
int VaneValue;       // raw analog value from wind vane
int Direction;       // translated 0 - 360 direction
int CalDirection;    // converted value with offset applied
int LastValue;
volatile bool IsSampleRequired;       // this is set true every 2.5s. Get wind speed
volatile unsigned int  TimerCount;    // used to determine 2.5sec timer count
volatile unsigned long Rotations;     // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime;  // Timer to avoid contact bounce in interrupt routine
float WindSpeed;        // speed miles per hour
  LastValue = 0;
  IsSampleRequired = false;
  TimerCount = 0;
  Rotations = 0;   // Set Rotations to 0 ready for calculations
  Serial.begin(9600);
  pinMode(WindSensorPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(WindSensorPin), isr_rotation, FALLING);
  Serial.println("Davis Anemometer Test");
  Serial.println("Speed (MPH)\tKnots\tDirection\tStrength");
  // Setup the timer intterupt
  Timer1.initialize(500000);
  Timer1.attachInterrupt(isr_timer);
  getWindDirection();
  // Only update the display if change greater than 5 degrees.
  if(abs(CalDirection - LastValue) > 5)
     LastValue = CalDirection;
  if(IsSampleRequired)
     // convert to mp/h using the formula V=P(2.25/T)
     // V = P(2.25/2.5) = P * 0.9
     WindSpeed = Rotations * 0.9;
     Rotations = 0;   // Reset count for next sample
     Serial.print(WindSpeed);    Serial.print("\t\t");
     Serial.print(getKnots(WindSpeed));    Serial.print("\t");
     Serial.print(CalDirection);
     getHeading(CalDirection);   Serial.print("\t\t");
     getWindStrength(WindSpeed);
// isr routine fr timer interrupt
void isr_timer() {
  TimerCount++;
  if(TimerCount == 5)
    IsSampleRequired = true;
    TimerCount = 0;
// This is the function that the interrupt calls to increment the rotation count
void isr_rotation ()   {
  if ((millis() - ContactBounceTime) > 15 ) {  // debounce the switch contact.
    Rotations++;
    ContactBounceTime = millis();
// Convert MPH to Knots
float getKnots(float speed) {
   return speed * 0.868976;
// Get Wind Direction
void getWindDirection() {
   VaneValue = analogRead(WindVanePin);
   Direction = map(VaneValue, 0, 1023, 0, 360);
   CalDirection = Direction + VaneOffset;
   if(CalDirection > 360)
     CalDirection = CalDirection - 360;
   if(CalDirection < 0)
     CalDirection = CalDirection + 360;
// Converts compass direction to heading
void getHeading(int direction) {
    if(direction < 22)
      Serial.print(" N");
    else if (direction < 67)
      Serial.print(" NE");
    else if (direction < 112)
      Serial.print(" E");
    else if (direction < 157)
      Serial.print(" SE");
    else if (direction < 212)
      Serial.print(" S");
    else if (direction < 247)
      Serial.print(" SW");
    else if (direction < 292)
      Serial.print(" W");
    else if (direction < 337)
      Serial.print(" NW");
      Serial.print(" N");
// converts wind speed to wind strength
void getWindStrength(float speed)
  if(speed < 2)
    Serial.println("Calm");
  else if(speed >= 2 && speed < 4)
    Serial.println("Light Air");
  else if(speed >= 4 && speed < 8)
    Serial.println("Light Breeze");
  else if(speed >= 8 && speed < 13)
    Serial.println("Gentle Breeze");
  else if(speed >= 13 && speed < 18)
    Serial.println("Moderate Breeze");
  else if(speed >= 18 && speed < 25)
    Serial.println("Fresh Breeze");
  else if(speed >= 25 && speed < 31)
    Serial.println("Strong Breeze");
  else if(speed >= 31 && speed < 39)
    Serial.println("Near Gale");
    Serial.println("RUN");
