Re: ESP6266wifi.h not working
Posted: Wed Mar 15, 2017 6:56 am
I don't have a solution to your main problem, but I do notice an error near the end.
should be
[the spelling of "replyPacket" has been fixed]
As for the original problem, it's almost certainly a case of some missing library --- but someone more expert with the system than I am can help you with that, I'll bet.
Udp.write(replyPacekt);
Udp.endPacket();
should be
Udp.write(replyPacket);
Udp.endPacket();
