Connection between NodeMCU ESP-12 and TJCTM24028-SPI
PostPosted: Sun Mar 26, 2017 2:56 pm
by Adzmo
Hey guys, i want to ask how to connect mentioned esp with 2.8 TFT SPI, i found this but is it even possible to connect these without breadboard?
I have this esp: Image
And this display: Image
Re: Connection between NodeMCU ESP-12 and TJCTM24028-SPI
PostPosted: Sun Mar 26, 2017 5:30 pm
by rudy
For me? Yes. For you? If you are asking then probably not. Do you have a soldering iron? I would use wirewrap wire to join the common connections on the display, on the other side. (not pin side)
But before you get too far into it. Try and connect to the LCD and get that working before trying the touch panel. One piece at a time. Then look at how to integrate both.
PostPosted: Sun Mar 26, 2017 5:51 pm
by Adzmo
Thank you for reply. How should i connect it if i dont need touch panel yet?
