I have copy pasted / written some code which creates an AP with a simple captive portal that display's all wifi networks available and then gives a box for the password and lets you connect the ESP to a wifi network.
Here is the code:
#include "./DNSServer.h" // Patched lib
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#define KEY1 "?Password%3A="
#define KEY2 " HTTP/1.1"
bool wifiConnect = false;
String scanResults;
bool gotClient = false;
WiFiClient client;
ESP8266WebServer webServer(80); // HTTP server
byte i = 0;
byte j = 0;
byte position = 0;
int digitalValues[9];
WiFiServer server(80);
String st;
//function prototypes:
void bubbleSort();
String scan() {
WiFi.disconnect();
delay(100);
int n = WiFi.scanNetworks();
String st = "<ul>";
for (int i = 0; i < n; ++i)
st += "<li>";
st += i + 1;
st += ": ";
st += WiFi.SSID(i);
st += " ";
st += "<form action=\"/";
st += WiFi.SSID(i);
st += "\" method=\"get\"><input type=\"text\" name=\"Password:\" placeholder=\"Password...\"><input type=\"submit\" value=\"Submit\"></form>";
st += "</li>";
st += "</ul>";
return st;
const byte DNS_PORT = 53; // Capture DNS requests on port 53
IPAddress apIP(10, 10, 10, 1); // Private network for server
DNSServer dnsServer; // Create the DNS object
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
scanResults = scan();
WiFi.mode(WIFI_AP_STA);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP("MY ESP8266 AP");
dnsServer.start(DNS_PORT, "*", apIP);
server.begin();
String username;
String password;
int getRequest() {
dnsServer.processNextRequest();
if (!client) {
return 3;
Serial.println("new client");
while (!client.available()) {
delay(1);
gotClient = true;
String request = client.readStringUntil('\r');
Serial.println(request);
// Match the request
if (strstr(request.c_str(), "Password%3A=") == NULL) {
Serial.println("Normal request");
return 2;
} else {
Serial.println("GET request");
char requestArray[50];
char *requestArray2;
request.toCharArray(requestArray, 50);
requestArray2 = requestArray + 4;
username = strtok(requestArray2, "/?");
strtok(NULL, " =");
password = strtok(NULL, " =");
return 1;
void sendResponse(int type) {
Serial.println("SENDING RESPONSE!");
String content;
content = "<!DOCTYPE HTML>";
content += "<html>";
if (type == 1) {
content += "<h2>Connect to a network...</h2><h4>This may take a few minutes...</h4>";
content += scanResults;
} else if (type == 2) {
content += "<br><h3>Could not connect to ";
content += username;
content += " please try again!</h3>";
content += ("</html>");
content += ("<style>h3{color: red}</style>");
} else {
content += "<h3>ESP8266 is now connected to ";
content += " and has been setup successfully!</h3>";
content += ("<style>h3{color: blue}</style>");
String header;
header = "HTTP/1.1 200 OK\r\n";
header += "Content-Type: text/html; charset=UTF-8\r\n";
header += "Content-Length: ";
header += content.length();
header += "\r\n";
header += "Connection: close\r\n\r\n";
client.println((header + content));
void wifi() {
int i = 0;
WiFi.begin(username.c_str(), password.c_str());
Serial.print(".");
if (i == 20) {
WiFi.disconnect();
WiFi.setOutputPower(0);
Serial.println("Timed out!");
sendResponse(2);
delay(5000);
return;
i++;
sendResponse(3);
Serial.println("");
while (wifiConnect == false) {
client = server.available();
int stat = getRequest();
//1 = Got creds 2 = Normal request 3 = No client
if (stat == 2) {
sendResponse(1);
} else if (stat == 1) {
Serial.println(username);
Serial.println(password);
wifiConnect = true;
wifi();
client.flush();
}For some very strange reason which I can't understand at all this works 100% fine when trying to connect to my WIFI network. If I enter the wrong password the response which tells the client it couldn't connect works completely fine on my wifi, and if I enter the correct password it works and I get the right response.
But when I try to connect to my neighbours wifi with the wrong password it doesn't tell me it couldn't connect, nothing happens at all! It just loops around and try's to connect again and again but never actually sending the response! I can't test wether the right password would send the response because I don't have it.
I am very frustrated and can't understand why it will only work on my wifi! If anyone could help I would really appreciate it.
Thanks, Dylan.
