I'm having some difficulty working with a stubborn ESP-01 module I have.
ESP-01 Black (says AI-Cloud inside on it)
I have flashed a few of these in the past and worked several projects..
however int he shuffle of new/old projects.. I no longer have my original 'flashing' test bed set-up.
So I tried to re-create it and flash these old ESP-01 modules I laying around with the latest (any firmware)
I cant get it to do much of ANYTHING however.. (hence the post to get some advice I may be overlooking)
Overview:
* No Arduino in the mix.
* USB/TTL programmer and ESP-01
I am using a breadboard to connect the programmer/regulator/ESP together (along with some latching switches for the GPIO 0 pin.. but have been removed for troubleshooting)
Programmer >> ESP
TX - 1k/2k voltage divider - RX
RX - TX
I have +5v from programmer going to +3.3v regulator
I have GND from programmer going to +3.3v regulator
CH_PD from ESP goes to regulated +3.3v
GPIO 0 from ESP goes to GND
V+ from ESP goes to regulated +3.3v
GND from ESP goes to GND
it does matter what flasher I download/try.. or even using the Arduino IDE itself and an example ESP (blink) sketch..
it never takes the firmware upload nor a sketch upload!!
I have tried both 9600 & 115200 baud rates.. but most errors still reference baud rate mis-match or something? (depending on the utility)
Firm I have tried:
ai-thinker-v1.1.1.bin
and some older ones I had downloaded:
In the Arduino IDE, I get this:
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failedIf I use something like:
ESPFlashDownloadTool_v3.4.4
I get:
test running: false
serial port opened
Connecting...
chip sync error
etc...
If I try to use this old utility:
XTCOM_UTIL.exe
I configure device: COM5 both 9600 and 115200 says "operation succeeded"
If I continue and click the 'connect' button... it goes through the 200 attempts. (it fails)
However.. when I am attempting to flash the firmware or use the Arduino IDE to upload a sketch.. I can see the little blue LED blink.
even when I open the serial monitor.. and type anything.. I see the blue led blink.
I never get the 'READY' test when I open the serial monitor either..
typing stuff doesnt get mirrored back.. just blink on blue led.
I have NOT kept up with the current/latest flashing utilities..
and I just grabbed the 1.1 .bin file as it the most recent I could find originally (older .bin files do not work either,. same results)
if anyone has a nice/stable flashing utility and a preferred .bin let me know and I'll give it a shot.
I'm not sure what could be wrong? Am I overlooking something simple?
All feedback is appreciated!
thanks!
