but i have a problem, when i send my file from my computer to esp8266, i can only find part of that on esp8266; for example when i send a 750kb file i can receive only 5 kb on esp8266 and i do n't know what is problem.
here is my code
uint8_t data = 0;
WiFiServer server(8888);
int counter = 0;
WiFi.softAP("akbar","akbar11041");
server.begin();
WiFiClient con = server.available();
if(con)
Serial.println("new connection");
counter = 0;
while(con.connected())
if(con.available())
counter += con.read(&data,1);
Serial.print(data);
Serial.println("Connection closed");
Serial.println("number of items :");
Serial.println(counter);
con.stop();
and i use below python code to send data to esp:
import socket
import time
fl = open("2.dat","rb")
data = fl.read()
con = socket.socket(socket.AF_INET,socket.SOCK_STREAM)
con.connect(("192.168.4.1",8888))
con.send(data)
con.close()
fl.close()
i am new in esp and i do n't know hove solve this problem,any one can help me ???
