https://www.aliexpress.com/item/1pcs-USB-to-ESP8266-Serial-Wireless-Wifi-Module-Developent-Board-8266-Wifi-Module/32695035976.html
I am trying to upload a program using Arduino IDE 1.8.1, and so I chose the ESP8266 Blink program from the examples menu.
I am basically trying to follow this: https://www.youtube.com/watch?v=m4fUswZSHcY
I soldered the jumper between Ground and GPIO 0 like in the video, push the upload button, and it says that it works:
Sketch uses 222197 bytes (51%) of program storage space. Maximum is 434160 bytes.
Global variables use 31572 bytes (38%) of dynamic memory, leaving 50348 bytes for local variables. Maximum is 81920 bytes.
C:\Users\andy\Documents\ArduinoData\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd ck -cb 115200 -cp COM9 -ca 0x00000 -cf C:\Users\andy\AppData\Local\Temp\arduino_build_173302/Blink.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM9
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2 bytes of data
Uploading 226352 bytes from C:\Users\andy\AppData\Local\Temp\arduino_build_173302/Blink.ino.bin to flash at 0x00000000
erasing flash
size: 037430 address: 000000
first_sector_index: 0
total_sector_count: 56
head_sector_count: 16
adjusted_sector_count: 40
erase_size: 028000
setting serial port timeouts to 15000 ms
writing flash
................................................................................ [ 36% ]
................................................................................ [ 72% ]
.............................................................. [ 100% ]
starting app without reboot
closing bootloader
flush start
flush complete
But the onboard LED doesn't start blinking like it does in the video.
If I unhook the jumper and replug it in, but still nothing happens.
Then I tried the CheckFlashConfig from the example menu because it has serial outputs, but when I upload it nothing happens and the serial monitor shows no activity.
Is there something that I am missing?
