I'm trying to compile a project with esp_iot_sdk 1.30
but I get "esptool: Permission denied" every time I hit make.
david@david-VirtualBox:~/myprojects/esp8266-injection-example$ ls -al
total 36
drwxrwxr-x 7 david david 4096 אפר 24 20:40 .
drwxrwxr-x 6 david david 4096 אפר 20 19:38 ..
drwxrwxr-x 2 david david 4096 אפר 20 16:51 driver
drwxrwxr-x 12 david david 4096 אפר 24 20:40 esp_iot_sdk_v1.3.0
drwxrwxr-x 8 david david 4096 אפר 20 16:51 .git
drwxrwxr-x 3 david david 4096 אפר 20 16:51 include
-rw-rw-r-- 1 david david 4069 אפר 20 19:44 Makefile
-rw-rw-r-- 1 david david 597 אפר 20 16:51 README.md
drwxrwxr-x 2 david david 4096 אפר 20 16:51 user
david@david-VirtualBox:~/myprojects/esp8266-injection-example$ sudo make clean
CC driver/uart.c
CC user/user_main.c
AR build/app_app.a
LD build/app.out
FW firmware/0x00000.bin
/bin/sh: 1: /home/david/myprojects/esptool: Permission denied
Makefile:109: recipe for target 'firmware/0x00000.bin' failed
make: *** [firmware/0x00000.bin] Error 126
I'm using esp-open sdk.
I downloaded esptool from here : http://filez.zoobab.com/esp8266/esptool-0.0.2.zip (according to step 2 here: https://github.com/cnlohr/ws2812esp8266) and made that my FW_TOOL
I'm tying to compile this project : https://github.com/pulkin/esp8266-injection-example.
I tried this solution but it didn't work (I tried to do it for the esptool folder in esp-open-sdk, and for the esptool folder I downloaded above) viewtopic.php?p=12465
I tried to do sudo chmod 777 esptool, for both esptool folders
And nothing works for me
Please help!
Here is my Makefile:
david@david-VirtualBox:~/myprojects/esp8266-injection-example$ cat Makefile
# tnx to mamalala
# Changelog
# Changed the variables to include the header file directory
# Added global var for the XTENSA tool root
# This make file still needs some work.
# Output directors to store intermediate compiled files
# relative to the project directory
BUILD_BASE = build
FW_BASE = firmware
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= ~/myprojects/esp-open-sdk/xtensa-lx106-elf/bin
# base directory of the ESP8266 SDK package, absolute
SDK_BASE ?= $(CURDIR)/esp_iot_sdk_v1.3.0
#Esptool.py path and port
ESPTOOL ?= ~/myprojects/esp-open-sdk/esptool/esptool.py
ESPPORT ?= /dev/ttyUSB0
# name for the target project
TARGET = app
# which modules (subdirectories) of the project to include in compiling
MODULES = driver user
EXTRA_INCDIR = include ~/myprojects/esp-open-sdk/xtensa-lx106-elf/include
# libraries used in this project, mainly provided by the SDK
LIBS = c gcc hal pp phy net80211 lwip wpa main
# compiler flags using during compilation of source files
CFLAGS = -Os -g -O2 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -D__ets__ -DICACHE_FLASH
# linker flags used to generate the main object file
LDFLAGS = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
# linker script used for the above linkier step
LD_SCRIPT = eagle.app.v6.ld
# various paths from the SDK used in this project
SDK_LIBDIR = lib
SDK_LDDIR = ld
SDK_INCDIR = include include/json
# we create two different files for uploading into the flash
# these are the names and options to generate them
FW_FILE_1 = 0x00000
FW_FILE_1_ARGS = -bo $@ -bs .text -bs .data -bs .rodata -bc -ec
FW_FILE_2 = 0x40000
FW_FILE_2_ARGS = -es .irom0.text $@ -ec
# select which tools to use as compiler, librarian and linker
CC := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
#### no user configurable options below here
FW_TOOL ?= ~/myprojects/esptool
SRC_DIR := $(MODULES)
BUILD_DIR := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC))
LIBS := $(addprefix -l,$(LIBS))
APP_AR := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR := $(addsuffix /include,$(INCDIR))
FW_FILE_1 := $(addprefix $(FW_BASE)/,$(FW_FILE_1).bin)
FW_FILE_2 := $(addprefix $(FW_BASE)/,$(FW_FILE_2).bin)
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
$(vecho) "CC $$<"
$(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS) -c $$< -o $$@
endef
.PHONY: all checkdirs flash clean
all: checkdirs $(TARGET_OUT) $(FW_FILE_1) $(FW_FILE_2)
$(FW_FILE_1): $(TARGET_OUT)
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_1_ARGS)
$(FW_FILE_2): $(TARGET_OUT)
$(vecho) "FW $@"
$(Q) $(FW_TOOL) -eo $(TARGET_OUT) $(FW_FILE_2_ARGS)
$(TARGET_OUT): $(APP_AR)
$(vecho) "LD $@"
$(Q) $(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
$(APP_AR): $(OBJ)
$(vecho) "AR $@"
$(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
$(Q) mkdir -p $@
firmware:
$(Q) mkdir -p $@
flash: firmware/0x00000.bin firmware/0x40000.bin
-$(ESPTOOL) --port $(ESPPORT) write_flash 0x00000 firmware/0x00000.bin 0x40000 firmware/0x40000.bin
clean:
$(Q) rm -f $(APP_AR)
$(Q) rm -f $(TARGET_OUT)
$(Q) rm -rf $(BUILD_DIR)
$(Q) rm -rf $(BUILD_BASE)
$(Q) rm -f $(FW_FILE_1)
$(Q) rm -f $(FW_FILE_2)
$(Q) rm -rf $(FW_BASE)
