rudy wrote:It is not a stupid question. From what I have seen it actually is difficult to do if you expect that to happen with any connecting device. (Apple, Windows, Android)
Do a search to Captive Portal.
Also search for .local
viewtopic.php?f=32&t=14807
viewtopic.php?p=61820
Thanks for the Response
. I have tried using captive portal before with some success. however it will only redirect if i type in something like google.com but if i just type google it wont redirect even though when uo type in google it goes to google.com/google ????? here is the code im using to test
#include "./DNSServer.h"
#include <lwip/def.h>
#include <Arduino.h>
#define DEBUG
#define DEBUG_OUTPUT Serial
DNSServer::DNSServer()
_ttl = htonl(60);
_errorReplyCode = DNSReplyCode::NonExistentDomain;
bool DNSServer::start(const uint16_t &port, const String &domainName,
const IPAddress &resolvedIP)
_port = port;
_domainName = domainName;
_resolvedIP[0] = resolvedIP[0];
_resolvedIP[1] = resolvedIP[1];
_resolvedIP[2] = resolvedIP[2];
_resolvedIP[3] = resolvedIP[3];
downcaseAndRemoveWwwPrefix(_domainName);
return _udp.begin(_port) == 1;
void DNSServer::setErrorReplyCode(const DNSReplyCode &replyCode)
_errorReplyCode = replyCode;
void DNSServer::setTTL(const uint32_t &ttl)
_ttl = htonl(ttl);
void DNSServer::stop()
_udp.stop();
void DNSServer::downcaseAndRemoveWwwPrefix(String &domainName)
domainName.toLowerCase();
domainName.replace("www.", "");
void DNSServer::processNextRequest()
_currentPacketSize = _udp.parsePacket();
if (_currentPacketSize)
_buffer = (unsigned char*)malloc(_currentPacketSize * sizeof(char));
_udp.read(_buffer, _currentPacketSize);
_dnsHeader = (DNSHeader*) _buffer;
if (_dnsHeader->QR == DNS_QR_QUERY &&
_dnsHeader->OPCode == DNS_OPCODE_QUERY &&
requestIncludesOnlyOneQuestion() &&
(_domainName == "*" || getDomainNameWithoutWwwPrefix() == _domainName)
replyWithIP();
else if (_dnsHeader->QR == DNS_QR_QUERY)
replyWithCustomCode();
free(_buffer);
bool DNSServer::requestIncludesOnlyOneQuestion()
return ntohs(_dnsHeader->QDCount) == 1 &&
_dnsHeader->ANCount == 0 &&
_dnsHeader->NSCount == 0 &&
_dnsHeader->ARCount == 0;
String DNSServer::getDomainNameWithoutWwwPrefix()
String parsedDomainName = "";
unsigned char *start = _buffer + 12;
if (*start == 0)
return parsedDomainName;
int pos = 0;
while(true)
unsigned char labelLength = *(start + pos);
for(int i = 0; i < labelLength; i++)
pos++;
parsedDomainName += (char)*(start + pos);
pos++;
if (*(start + pos) == 0)
downcaseAndRemoveWwwPrefix(parsedDomainName);
else
parsedDomainName += "www";
void DNSServer::replyWithIP()
_dnsHeader->QR = DNS_QR_RESPONSE;
_dnsHeader->ANCount = _dnsHeader->QDCount;
_dnsHeader->QDCount = _dnsHeader->QDCount;
//_dnsHeader->RA = 1;
_udp.beginPacket(_udp.remoteIP(), _udp.remotePort());
_udp.write(_buffer, _currentPacketSize);
_udp.write((uint8_t)192); // answer name is a pointer
_udp.write((uint8_t)12); // pointer to offset at 0x00c
_udp.write((uint8_t)0); // 0x0001 answer is type A query (host address)
_udp.write((uint8_t)1);
_udp.write((uint8_t)0); //0x0001 answer is class IN (internet address)
_udp.write((unsigned char*)&_ttl, 4);
// Length of RData is 4 bytes (because, in this case, RData is IPv4)
_udp.write((uint8_t)4);
_udp.write(_resolvedIP, sizeof(_resolvedIP));
_udp.endPacket();
#ifdef DEBUG
DEBUG_OUTPUT.print("DNS responds: ");
DEBUG_OUTPUT.print(_resolvedIP[0]);
DEBUG_OUTPUT.print(".");
DEBUG_OUTPUT.print(_resolvedIP[1]);
DEBUG_OUTPUT.print(_resolvedIP[2]);
DEBUG_OUTPUT.print(_resolvedIP[3]);
DEBUG_OUTPUT.print(" for ");
DEBUG_OUTPUT.println(getDomainNameWithoutWwwPrefix());
#endif
void DNSServer::replyWithCustomCode()
_dnsHeader->RCode = (unsigned char)_errorReplyCode;
_dnsHeader->QDCount = 0;
_udp.write(_buffer, sizeof(DNSHeader));
_udp.endPacket();
