This is almost my first attempt of using the ESP8266. I have a NodeMCU 0.9 and I want to test it with a PIR sensor. Ultimatey, I'll send an intrusion alarm to a RPi...
But right now, I just want to have the PRI sensor work properly. I have done this before on the RPi so I know how it works. But there is something wrong with the NodeMCU.
I use the sketch that can be found everywhere on the net (see below).
* PIR sensor tester
int ledPin = 4; // choose the pin for the LED
int inputPin = 14; // choose the input pin (for PIR sensor)
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare sensor as input
Serial.begin(9600);
void loop(){
val = digitalRead(inputPin); // read input value
Serial.println(val);
if (val == HIGH) { // check if the input is HIGH
digitalWrite(ledPin, HIGH); // turn LED ON
if (pirState == LOW) {
// we have just turned on
Serial.println("Motion detected!");
// We only want to print on the output change, not state
pirState = HIGH;
} else {
digitalWrite(ledPin, LOW); // turn LED OFF
if (pirState == HIGH){
// we have just turned of
Serial.println("Motion ended!");
pirState = LOW;
}The LED is connected to D2 pin and the signal of the PIR sensor to the D5. I'm not sure about which pin is 5V and which is ground on the sensor.
When I run the sketch, the value of the sensor remains high forever and the LED is lit. I can't have any movement detection. What's wrong ?
Thanks for your help
