espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Someone pls Help
Explore... Chat... Share...
QuickFix wrote:After power on or at manual reset (with the RST-button on the board), the blue LED on the ESP itself should at least blink a few times.
Does yours?
You'd better temporary remove the NodeMCU from the breadboard, to rule that out.
I don't know where the blue LED on your board is for (I don't have one).
