I scoped the SDA and SLC lines and these look reasonable but the I2C Scanner code does not find the shield at address 0x28 like the DUE or Mega do.
#include <Wire.h>
void setup()
Wire.begin(D2,D1); //(SDA,SCL)
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Serial.print("I2C scan address 0x"); Serial.print("0");
Serial.print(address,HEX);
Serial.print(" ! error=");
Wire.beginTransmission(address);
error = Wire.endTransmission();
Serial.println(error);
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknow error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
// delay(5000); // wait 5 seconds for next scan
}Thanks
Kurt
