#include <Arduino.h>
#include <ESP8266WiFiMulti.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
const String Cadenadatos = "info=Servetumamaesmia|06/09/2017 19:27 |25\r\n" ;
const String Tamano = String(Cadenadatos.length()) ;
const String urlfinal = "POST /wsCo2Keellingv1002/wsCo2Kelling.asmx/GuardarInfoArduino\r\nHTTP/1.1\r\nHost:187.201.44.110\r\nContent-Type:application/x-www-form-urlencoded\r\n\r\n"+String(Cadenadatos)+"\r\n" ;
void setup()
USE_SERIAL.begin(9600);
// USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
USE_SERIAL.flush();
delay(1000);
WiFiMulti.addAP("Putostodosmenosyo", "CetriX.2016%Gdl");
delay(2000) ;
/* if(WiFi.status() != available())
USE_SERIAL.print("Conectado a la red") ;
USE_SERIAL.println("No se pudo conectar a la red") ;*/
void loop()
// wait for WiFi connection
if((WiFiMulti.run() == WL_CONNECTED)) {
HTTPClient http;
USE_SERIAL.print("[HTTP] begin...\n");
// configure traged server and url
//http.begin("https://192.168.1.12/test.html", "7a 9c f4 db 40 d3 62 5a 6e 21 bc 5c cc 66 c8 3e a1 45 59 38"); //HTTPS
http.begin("co2kelling.hopto.org"); //HTTP
USE_SERIAL.print("POST /wsCo2Keellingv1002/wsCo2Keelling.asmx/GuardarInfoArduino HTTP/1.1\r\n") ;
//USE_SERIAL.print("") ;
//USE_SERIAL.print("");
//USE_SERIAL.print("HTTP/1.1\r\n") ;
USE_SERIAL.print("Host:187.248.44.110\r\n");
USE_SERIAL.print("Content-Type: application/x-www-form-urlencoded\r\n");
USE_SERIAL.print("Content-Length: "+String(Tamano)+"\r\n");
USE_SERIAL.print("\r\n") ;
USE_SERIAL.print("info="+String(Tamano)+"\r\n") ;
// USE_SERIAL.end() ;
//USE_SERIAL.print("GuardarInfoArduino HTTP/1.1\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if(httpCode > 0)
// HTTP header has been send and Server response header has been handled
USE_SERIAL.printf("[HTTP] POST... code: %d\n", httpCode);
// file found at server
if(httpCode == HTTP_CODE_OK)
USE_SERIAL.println(payload);
USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(10000);
I want to send a HTTP POST NOT a HTTP GET but I recevied response the next thing:
[HTTP] begin...
Host:187.248.44.110
Content-Length: 44
info=44
[HTTP] GET... failed, error: connection refused
I tried to change the code part:
int httpCode = http.GET();to "http.POST();"
But at time of compile I received of error:
/media/mareyes/EE73-2845/asdasd/asdasd.ino: In function 'void loop()':
asdasd:73: error: no matching function for call to 'HTTPClient::POST()'
int httpCode = http.POST();
/media/mareyes/EE73-2845/asdasd/asdasd.ino:73:34: note: candidates are:
In file included from /media/mareyes/EE73-2845/asdasd/asdasd.ino:12:0:
/home/mareyes/.arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.h:157:9: note: int HTTPClient::POST(uint8_t*, size_t)
int POST(uint8_t * payload, size_t size);
/home/mareyes/.arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.h:157:9: note: candidate expects 2 arguments, 0 provided
/home/mareyes/.arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.h:158:9: note: int HTTPClient::POST(String)
int POST(String payload);
/home/mareyes/.arduino15/packages/esp8266/hardware/esp8266/2.3.0/libraries/ESP8266HTTPClient/src/ESP8266HTTPClient.h:158:9: note: candidate expects 1 argument, 0 provided
exit status 1
