Here is the relevant code:
#include <FastLED.h>
#include <LEDMatrix.h>
#include <LEDText.h>
#include <FontRobotron.h>
#include <FontMatrise.h>
#include <WiFiClient.h>
#include <PubSubClient.h>
const char *ssid = "TruffleShuffle";
const char *password = "Mets1234";
WiFiClient espClient;
PubSubClient mqttclient(espClient);
// Change the next 6 defines to match your matrix type and size
#define LED_PIN 7 //GPIO13
#define COLOR_ORDER GRB
#define CHIPSET WS2812B
#define MATRIX_WIDTH 60
#define MATRIX_HEIGHT 7
#define MATRIX_TYPE HORIZONTAL_ZIGZAG_MATRIX
#define MAXMSG 2
cLEDMatrix<MATRIX_WIDTH, MATRIX_HEIGHT, MATRIX_TYPE> leds;
cLEDText ScrollingMsg;
char TxtDemo[] = { " INTRO MESSAGE "};
String msgList[MAXMSG];
int currentMsgIdx=0;
int totalMsg=0;
int nextSlot = 0;
void setup()
Serial.setDebugOutput(true);
dbg("Attempting wifi connection");
delay(100);
WiFi.begin ( ssid, password );
FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds[0], leds.Size());
FastLED.setBrightness(64);
FastLED.clear(true);
delay(100);
while ( WiFi.status() != WL_CONNECTED ) {
delay ( 100 );
FastLED.showColor(CRGB::Red);
delay(100);
FastLED.showColor(CRGB::Lime);
delay(100);
FastLED.showColor(CRGB::Blue);
delay(100);
FastLED.showColor(CRGB::White);
connectToMQTT();
FastLED.show();
msgList[0]= " Welcome, test message !";
totalMsg=1;
nextSlot=1;
//ScrollingMsg.SetFont(RobotronFontData);
ScrollingMsg.SetFont(MatriseFontData);
ScrollingMsg.Init(&leds, leds.Width(), ScrollingMsg.FontHeight() + 1, 0, 0);
ScrollingMsg.SetText((unsigned char *)TxtDemo, sizeof(TxtDemo) - 1);
ScrollingMsg.SetTextColrOptions(COLR_RGB | COLR_SINGLE, 0xff, 0x00, 0xff);
void loop()
if (ScrollingMsg.UpdateText() == -1){
mqttclient.loop();
delay(150);
currentMsgIdx++;
int max = (totalMsg > MAXMSG ? MAXMSG : totalMsg);
if (currentMsgIdx >= max){
currentMsgIdx = 0;
dbg("Displaying msgidx "+String(currentMsgIdx));
int len = msgList[currentMsgIdx].length();
char textPtr[len+1];
char * msgStr;
dbg("Length of msg: "+String(len));
msgList[currentMsgIdx].toCharArray(textPtr,len+1);
textPtr[len]='\0';
dbg("length of textptr"+String(strlen(textPtr)));
dbg("Setting text to ");
dbg(String(textPtr));
/* dbg("CHARS:");
for (int i =0; i < sizeof(textPtr); i++){
Serial.print(textPtr[i]);
dbg(":ENDCHARS");*/
dbg("SIZE OF"+String(sizeof(textPtr)-1));
//This shows some gibberish and I cant figure out why
strcpy(msgStr,textPtr);
ScrollingMsg.SetText((unsigned char *)msgStr, sizeof(msgStr)-1);
//WORKS! but truncates the message based on the orginal size of TxtDemo
//strcpy(TxtDemo,textPtr);
//ScrollingMsg.SetText((unsigned char *)TxtDemo, sizeof(TxtDemo) - 1);
FastLED.show();
delay(10);
}Near the bottom you'll the strcpy to msgStr, when using that code the LED shows some gibberish. However, when I use the code directly below (commented out) text shows up fine although it is truncated. Also if I replace:
char * msg;char msg[43];char msg[len+1];I'm pretty lost as to what is going on. Any guidance is greatly appreciated.
