Editor and Tablet ...???
Posted: Fri Jun 23, 2017 1:46 pm
Hello! I want to start with the temp sensor using the DS18b20 and go from there. I have a ESP8266-01 board and a DS18b20 temp sensor. I use a USB to serial 3.3 Volt converter to interface with the board. I tried to get it to work a while back and never got it to work. I have tried to find help with the project and had no luck. I am thinking for getting a tablet to use with this project. The questions are, what tablets can I use? Windows should work. What about Android Tablets? Then the others... I am looking for an inexpensive one too... Next question, will the tablet USB power the board? Mini USB or standard? I have a power bank that I might be able to power the project with using a "Y" USB cable.
The next thing is what is a good LUA editor to use. I would like to be able to send command line to it as I work with it and see the response. That will also depend on the operating system of the tablet.
I have a tiny bit of programming experience with basic and Pascal.
Any and all help appreciated!
Thank you
Joe
Thank you
Joe
