Page 1 of 2
ESP-201
PostPosted: Sat Jun 24, 2017 2:21 pm
by kondorcl
I have new esp-201 after uploading Blinking ide arduino sketch and reset it. I have from esp-201:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
รก
Please ur help will be appreciated.
Re: ESP-201
PostPosted: Sat Jun 24, 2017 9:02 pm
by atexit8
Never heard of ESP-201.
Re: ESP-201
PostPosted: Sun Jun 25, 2017 9:07 am
by QuickFix
I've seen the ESP-201 before and as far as I know it doesn't have an on-board LED, though never owned one, so I could be wrong.
Please copy the sketch to this forum, enclosing it with the CODE-tags and tell us how you (tro to) upload it to your ESP.
The ESP currently boots up okay, but if it isn't doing what you expect (blinking) you must have done something wrong either while uploading (you didn't actually upload anything) or using the sketch (assuming the LED defined in the sketch is on the correct port-pin).
Re: ESP-201
PostPosted: Sun Jun 25, 2017 11:17 am
by kondorcl
Here the code:
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model, check
the documentation at http://www.arduino.cc
This example code is in the public domain.
modified 8 May 2014
by Scott Fitzgerald
// the setup function runs once when you press reset or power the board
Serial.println("Blink Test LED");
// initialize digital pin 7 as an output.
pinMode(7, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(7, HIGH); // turn the LED on (HIGH is the voltage level)
Serial.println("LED High");
delay(1000); // wait for a second
digitalWrite(7, LOW); // turn the LED off by making the voltage LOW
Serial.println("LED Low");
and response while uploading.
Uploading 228464 bytes from C:\Users\Enrique\Documents\Arduino\HEX/Blink.cpp.bin to flash at 0x00000000
................................................................................ [ 35% ]
................................................................................ [ 71% ]
................................................................ [ 100% ]
Thank againg.
