I got an email back from the developer of this module. Apparently the -99 return code is a minor bug and always happens when you initiate a close. I still haven't been able to make the test where I open the socket, send a message, and then close the socket work reliably though.
The following is the terminal output with my current code after adding some manual garbage collection statements to see if that is a part of the problem. It looks like quite often something just isn't letting go when I try to close - and it takes the module 10 minutes to figure it out and resume normal operation.
Code: Select alldofile("websocket2.lua")
Running websocket2.lua
> Pre-collect heap available:36760
Post-collect heap available:36792
Tx:1
Rx: ServerABC: Websocket message number 1
Pre-collect heap available:34104
Post-collect heap available:34200
websocket not available
Then 10 minutes worth of this printing over and over:
Pre-collect heap available:34152
Ws closed, code: -103
Pre-collect heap available:36304
Post-collect heap available:36600
Tx:2
Rx: ServerABC: Websocket message number 2
Ws closed, code: -99
Pre-collect heap available:34320
Post-collect heap available:34616
Tx:3
Rx: ServerABC: Websocket message number 3
Pre-collect heap available:32352
Post-collect heap available:32648
Tx:4
Rx: ServerABC: Websocket message number 4
Pre-collect heap available:32120
Post-collect heap available:32224
Pre-collect heap available:34144
Post-collect heap available:34192
Tx:5
Rx: ServerABC: Websocket message number 5
Tx:6
Rx: ServerABC: Websocket message number 6
Pre-collect heap available:32344
Post-collect heap available:32640
Tx:7
Rx: ServerABC: Websocket message number 7
Tx:8
Rx: ServerABC: Websocket message number 8
Tx:9
Rx: ServerABC: Websocket message number 9
Tx:10
Rx: ServerABC: Websocket message number 10
Tx:11
Rx: ServerABC: Websocket message number 11
Tx:12
Rx: ServerABC: Websocket message number 12
Pre-collect heap available:32336
Post-collect heap available:32632
Tx:13
Rx: ServerABC: Websocket message number 13
Tx:14
Rx: ServerABC: Websocket message number 14
Tx:15
Rx: ServerABC: Websocket message number 15
Tx:16
Rx: ServerABC: Websocket message number 16
Tx:17
Rx: ServerABC: Websocket message number 17
Pre-collect heap available:32368
Post-collect heap available:32664
Tx:18
Rx: ServerABC: Websocket message number 18
Tx:19
Rx: ServerABC: Websocket message number 19
Tx:20
Rx: ServerABC: Websocket message number 20
Tx:21
Rx: ServerABC: Websocket message number 21
Tx:22
Rx: ServerABC: Websocket message number 22
Tx:23
Rx: ServerABC: Websocket message number 23
Tx:24
Rx: ServerABC: Websocket message number 24
Tx:25
Rx: ServerABC: Websocket message number 25
Tx:26
Rx: ServerABC: Websocket message number 26
Tx:27
Rx: ServerABC: Websocket message number 27
Pre-collect heap available:32128
Post-collect heap available:32232
Tx:28
Rx: ServerABC: Websocket message number 28
Tx:29
Rx: ServerABC: Websocket message number 29
Pre-collect heap available:32360
Post-collect heap available:32656
Tx:30
Rx: ServerABC: Websocket message number 30
I have concerns about scope in my code where I'm relying on the callbacks that live inside the send_websocket_message function to still work after the function has exited, but I ran into problems trying to move the callbacks outside of send_websocket_message. When I do that with the ws_connect function my call to ws:send results in a panic message because the websocket isn't connected - but the whole reason we got into ws_connect was because of the "connection" event. I don't know what I'm doing wrong - I'm pretty new to lua scripting.
Here's the code with the calls inside the send_websocket_message function. This code resulted in the output I posted above:
Code: Select all-- This file creates websocket connection, sends a test message, closes the connection, and then repeats
print("Running websocket2.lua")
local message_timer = tmr.create() -- Timer used to periodically open the socket and send a message
local message_counter = 1 -- Counter variable for test messages
local ws = nil -- Websocket handle
-- In this test, the following function just establishes the connection and the send happens in the "on connection" method
function send_websocket_message()
print("Pre-collect heap available:" .. node.heap())
collectgarbage("collect")
print("Post-collect heap available:" .. node.heap())
if ws == nil then
ws = websocket.createClient()
-- Register the callback function for when a connection is established
ws:on("connection",
function(ws_connect)
message = "Websocket message number "..message_counter
print("Tx:"..message_counter)
message_counter = message_counter + 1
ws:send(message)
-- Set up a timer to shut down the websocket connection
--if not tmr.create():alarm(500, tmr.ALARM_SINGLE, function()
--print('Websocket test done - closing the connection')
--if (ws ~= nil) then
--ws:close()
--end
--end)
--then
--print("Timer already exists - shouldn't happen")
--end
-- Stop the timer that calls send_websocket_message after a specified number of messages
if message_counter > 30 then
message_timer:stop()
message_timer:unregister()
end
end)
-- Register the callback function for when the websocket is closed
ws:on("close",
function(ws_close, status)
print('Ws closed, code:', status)
ws = nil
end)
-- Register the callback function for when data is received
ws:on("receive",
function(ws_receive, msg, opcode)
print('Rx:', msg)
ws:close()
end)
-- Issue the websocket connect command
ws:connect('ws://ADDRESS_REMOVED')
else
print("websocket not available")
end
end
-- Start a timer that will call send_websocket_message at the specified number of milliseconds
message_timer:register(5000, tmr.ALARM_AUTO, send_websocket_message)
message_timer:start()
Here is the code with the callbacks moved out - this code doesn't work at all, but I don't know why
function ws_connect()
if (ws ~= nil) then
ws:send(message)
end
--ws:close()
--end
--end)
--then
--end
end
end
function ws_close(status)
ws = nil
end
function ws_receive(msg, opcode)
print('Rx:', msg)
if (ws ~= nil) then
ws:close()
end
end
if ws == nil then
ws:on("connection", ws_connect())
ws:on("close", ws_close(status))
ws:on("receive", ws_receive(msg, opcode))
else
end
end
