WiFi.hostname(host_name);
Doesn't work ???
Explore... Chat... Share...
martinayotte wrote:What do you mean "not working" ?
Does your router shows that ESP3 hostname in the IP leases list ?
Don't expect to be able to do "ping ESP3", it won't work since the DNS doesn't know this hostname.
Use mDNS service on your ESP, install Bonjour on Windows, and then "ESP3.local" will be resolved.
MyESPAP-192B86 192.168.0.101 60:01:94:19:2b:86 23 Hours 55 MinutesIt takes about 20-25 seconds for home assistant c[…]
