By Victor Santos
#68939 Hello Peeps,
Can someone pls tell me whats wrong with this code....
Button 2 doesnt work.
const char* ssid     = "***";
const char* password = "***";
const char* host = "192.168.1.90";
// set pin numbers:
const int buttonPin1 = 5;     // the number of the pushbutton pin 5
const int buttonPin2 = 4;     // the number of the pushbutton pin 4
// variables will change:
int buttonState1 = 1;         // variable for reading the pushbutton status
int buttonState2 = 1;         // variable for reading the pushbutton status
 WiFi.begin(ssid, password);
 // initialize the LED pin as an output:
 pinMode(buttonPin1, INPUT_PULLUP);
 pinMode(buttonPin2, INPUT_PULLUP);
void loop(){
 buttonState1 = digitalRead(buttonPin1);
if (buttonState1 == 0) {
   // turn button on:   //
 delay(5000);
  WiFiClient client;
  const int httpPort1 = 80;
  if (!client.connect(host, httpPort1)) {
    return;
  String url1 = "http://192.168.1.90/salvardados.php?teste1";
  client.print(String("GET ") + url1 + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
buttonState2 = digitalRead(buttonPin2);
 //////////////////////////////////////button 2////////////////////////////////////
else if (buttonState2 == 0) {
 delay(5000);
  WiFiClient client;
  const int httpPort2 = 80;
  if (!client.connect(host, httpPort2)) {
    return;
  String url2 = "http://192.168.1.90/salvardados.php?teste2";
  client.print(String("GET ") + url2 + " HTTP/1.1\r\n" +
