By gmonds
#69021 K. So I've got my door sensor working great...then i thought. Wouldn't it be great to monitor the battery level. The raw data coming back looks a bit wonky...I was expecting some nice decreasing value. :)
Using the battery monitor circuit from https://learn.adafruit.com/using-ifttt-with-adafruit-io/wiring#battery-tracking
I get values as follows...but they would not map nicely.
Code: Select all2017-08-12 00:27:55.657 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 182
2017-08-12 00:31:00.296 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 182 to 140
2017-08-12 00:34:04.323 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 140 to 154
2017-08-12 00:37:08.531 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 149
2017-08-12 00:40:12.595 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 153
2017-08-12 00:43:16.766 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 138
2017-08-12 00:46:20.893 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 138 to 159
2017-08-12 00:49:25.039 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 160
2017-08-12 00:52:29.161 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 165
2017-08-12 00:55:33.272 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 154
2017-08-12 00:58:37.404 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 152
2017-08-12 01:01:41.589 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 152 to 157
2017-08-12 01:04:45.775 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 156
2017-08-12 01:07:49.845 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 158
2017-08-12 01:10:53.964 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 156
2017-08-12 01:13:58.078 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 155
2017-08-12 01:17:02.143 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 153
2017-08-12 01:23:11.265 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 162
2017-08-12 01:26:15.360 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 158
2017-08-12 01:29:19.475 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 147
2017-08-12 01:32:23.635 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 153
2017-08-12 01:35:27.785 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 151
2017-08-12 01:38:31.906 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 151 to 137
2017-08-12 01:41:36.055 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 137 to 149
2017-08-12 01:44:40.204 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 135
2017-08-12 01:47:44.346 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 135 to 144
2017-08-12 01:50:48.464 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 144 to 150
2017-08-12 01:53:52.609 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 149
2017-08-12 01:56:56.698 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 108
2017-08-12 02:00:00.806 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 108 to 124
2017-08-12 02:03:04.930 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 124 to 153
2017-08-12 02:06:09.069 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 144
2017-08-12 02:09:13.191 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 144 to 135
2017-08-12 02:12:17.260 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 135 to 147
2017-08-12 02:15:21.391 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 118
2017-08-12 02:18:26.373 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 118 to 148
2017-08-12 02:21:30.473 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 150
2017-08-12 02:24:34.623 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 153
2017-08-12 02:27:38.713 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 138
2017-08-12 02:30:42.862 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 138 to 165
2017-08-12 02:33:46.954 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 155
2017-08-12 02:36:51.113 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 163
2017-08-12 02:39:55.232 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 161
2017-08-12 02:42:59.390 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 162
2017-08-12 02:46:03.505 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 153
2017-08-12 02:49:07.668 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 163
2017-08-12 02:52:12.256 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 121
2017-08-12 02:55:16.338 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 121 to 161
2017-08-12 02:58:20.446 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 160
2017-08-12 03:01:24.548 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 154
2017-08-12 03:04:28.642 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 153
2017-08-12 03:07:32.752 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 158
2017-08-12 03:10:36.882 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 149
2017-08-12 03:16:45.999 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 148
2017-08-12 03:19:50.168 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 160
2017-08-12 03:22:54.271 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 155
2017-08-12 03:25:58.335 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 158
2017-08-12 03:29:02.504 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 162
2017-08-12 03:32:06.573 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 161
2017-08-12 03:35:10.658 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 157
2017-08-12 03:38:14.720 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 159
2017-08-12 03:41:18.862 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 163
2017-08-12 03:44:23.001 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 164
2017-08-12 03:47:27.139 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 163
2017-08-12 03:50:31.259 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 164
2017-08-12 03:53:35.395 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 151
2017-08-12 03:56:39.464 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 151 to 145
2017-08-12 03:59:43.559 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 145 to 150
2017-08-12 04:02:47.674 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 155
2017-08-12 04:05:51.826 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 157
2017-08-12 04:08:55.925 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 163
2017-08-12 04:12:00.016 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 148
2017-08-12 04:15:05.009 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 155
2017-08-12 04:18:09.158 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 153
2017-08-12 04:21:13.230 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 159
2017-08-12 04:24:17.298 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 163
2017-08-12 04:27:21.375 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 151
2017-08-12 04:30:25.481 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 151 to 144
2017-08-12 04:33:29.630 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 144 to 145
2017-08-12 04:36:33.787 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 145 to 149
2017-08-12 04:39:37.922 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 154
2017-08-12 04:42:42.485 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 152
2017-08-12 04:45:46.556 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 152 to 148
2017-08-12 04:48:50.640 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 161
2017-08-12 04:51:54.760 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 147
2017-08-12 04:54:58.897 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 150
2017-08-12 04:58:02.977 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 147
2017-08-12 05:01:07.093 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 154
2017-08-12 05:04:11.224 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 161
2017-08-12 05:07:15.383 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 148
2017-08-12 05:10:19.421 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 123
2017-08-12 05:13:24.366 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 123 to 151
2017-08-12 05:16:28.412 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 151 to 152
2017-08-12 05:19:32.536 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 152 to 160
2017-08-12 05:22:36.642 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 159
2017-08-12 05:25:40.748 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 155
2017-08-12 05:28:44.815 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 113
2017-08-12 05:31:48.882 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 113 to 149
2017-08-12 05:34:53.020 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 154
2017-08-12 05:37:57.123 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 164
2017-08-12 05:41:01.236 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 134
2017-08-12 05:44:05.395 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 134 to 158
2017-08-12 05:47:09.503 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 154
2017-08-12 05:50:13.610 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 165
2017-08-12 05:53:17.694 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 152
2017-08-12 05:56:21.820 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 152 to 159
2017-08-12 05:59:25.915 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 166
2017-08-12 06:02:30.044 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 165
2017-08-12 06:05:34.200 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 153
2017-08-12 06:08:38.271 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 157
2017-08-12 06:11:43.187 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 164
2017-08-12 06:14:47.313 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 175
2017-08-12 06:17:51.375 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 155
2017-08-12 06:20:55.482 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 167
2017-08-12 06:23:59.532 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 170
2017-08-12 06:27:03.641 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 170 to 163
2017-08-12 06:30:07.808 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 165
2017-08-12 06:33:11.861 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 166
2017-08-12 06:36:16.026 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 165
2017-08-12 06:39:20.098 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 179
2017-08-12 06:42:24.205 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 164
2017-08-12 06:45:28.292 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 166
2017-08-12 06:48:32.423 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 164
2017-08-12 06:51:36.553 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 163
2017-08-12 06:57:44.688 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 164
2017-08-12 07:00:48.758 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 159
2017-08-12 07:03:52.872 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 161
2017-08-12 07:06:57.020 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 159
2017-08-12 07:10:01.961 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 171
2017-08-12 07:13:05.989 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 171 to 156
2017-08-12 07:16:10.502 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 182
2017-08-12 07:19:14.613 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 182 to 166
2017-08-12 07:22:18.740 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 159
2017-08-12 07:25:22.805 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 166
2017-08-12 07:28:26.856 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 169
2017-08-12 07:31:30.926 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 169 to 161
2017-08-12 07:34:35.052 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 157
2017-08-12 07:37:39.141 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 166
2017-08-12 07:40:43.301 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 167
2017-08-12 07:43:47.371 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 179
2017-08-12 07:46:51.474 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 160
2017-08-12 07:49:55.603 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 162
2017-08-12 07:52:59.701 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 175
2017-08-12 07:56:03.761 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 162
2017-08-12 07:59:07.873 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 167
2017-08-12 08:02:12.063 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 179
2017-08-12 08:05:16.224 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 176
2017-08-12 08:08:21.142 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 176 to 174
2017-08-12 08:11:25.233 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 174 to 167
2017-08-12 08:14:29.358 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 174
2017-08-12 08:17:33.454 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 174 to 171
2017-08-12 08:20:37.555 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 171 to 163
2017-08-12 08:26:45.757 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 164
2017-08-12 08:29:49.821 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 165
2017-08-12 08:32:53.921 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 162
2017-08-12 08:35:57.997 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 150
2017-08-12 08:39:02.133 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 153
2017-08-12 08:42:06.292 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 173
2017-08-12 08:45:10.430 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 173 to 164
2017-08-12 08:48:15.402 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 162
2017-08-12 08:51:19.535 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 156
2017-08-12 08:54:23.713 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 157
2017-08-12 08:57:27.853 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 146
2017-08-12 09:00:31.956 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 146 to 162
2017-08-12 09:03:36.105 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 155
2017-08-12 09:06:41.016 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 149
2017-08-12 09:09:45.081 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 158
2017-08-12 09:12:49.163 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 156
2017-08-12 09:15:53.262 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 155
2017-08-12 09:18:57.443 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 157
2017-08-12 09:22:01.466 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 131
2017-08-12 09:25:06.105 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 131 to 148
2017-08-12 09:31:14.294 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 146
2017-08-12 09:34:18.478 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 146 to 166
2017-08-12 09:37:22.524 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 163
2017-08-12 09:40:26.645 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 169
2017-08-12 09:43:30.763 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 169 to 148
2017-08-12 09:46:34.830 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 162
2017-08-12 09:49:38.929 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 150
2017-08-12 09:52:43.019 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 155
2017-08-12 09:55:47.217 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 164
2017-08-12 09:58:51.349 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 167
2017-08-12 10:01:56.471 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 155
2017-08-12 10:05:00.419 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 141
2017-08-12 10:08:04.538 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 141 to 149
2017-08-12 10:11:08.690 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 155
2017-08-12 10:14:12.825 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 164
2017-08-12 10:17:16.955 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 160
2017-08-12 10:20:21.086 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 154
2017-08-12 10:23:25.203 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 161
2017-08-12 10:26:29.330 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 163
2017-08-12 10:29:33.512 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 156
2017-08-12 10:32:37.606 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 165
2017-08-12 10:35:41.669 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 166
2017-08-12 10:38:45.806 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 161
2017-08-12 10:41:49.916 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 164
2017-08-12 10:44:54.113 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 159
2017-08-12 10:47:58.655 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 149
2017-08-12 10:51:02.695 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 160
2017-08-12 10:54:06.816 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 160 to 162
2017-08-12 10:57:10.974 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 157
2017-08-12 11:00:16.114 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 166
2017-08-12 11:03:20.104 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 163
2017-08-12 11:06:24.271 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 165
2017-08-12 11:09:28.391 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 164
2017-08-12 11:12:32.454 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 173
2017-08-12 11:15:36.599 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 173 to 183
2017-08-12 11:18:40.641 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 175
2017-08-12 11:21:44.680 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 172
2017-08-12 11:24:48.761 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 172 to 68
2017-08-12 11:27:52.866 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 68 to 150
2017-08-12 11:30:56.944 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 150 to 98
2017-08-12 11:34:01.003 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 98 to 141
2017-08-12 11:37:05.144 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 141 to 84
2017-08-12 11:40:09.259 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 84 to 162
2017-08-12 11:43:13.359 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 159
2017-08-12 11:46:17.466 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 157
2017-08-12 11:49:21.521 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 139
2017-08-12 11:52:25.618 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 139 to 121
2017-08-12 11:55:29.701 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 121 to 157
2017-08-12 11:58:34.675 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 156
2017-08-12 12:01:38.647 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 132
2017-08-12 12:04:42.716 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 132 to 137
2017-08-12 12:07:46.756 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 137 to 136
2017-08-12 12:10:50.827 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 136 to 138
2017-08-12 12:13:54.906 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 138 to 153
2017-08-12 12:16:59.040 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 155
2017-08-12 12:20:03.174 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 167
2017-08-12 12:23:07.327 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 145
2017-08-12 12:26:11.459 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 145 to 189
2017-08-12 12:29:15.992 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 187
2017-08-12 12:32:20.093 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 189
2017-08-12 12:35:24.188 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 187
2017-08-12 12:38:28.321 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 196
2017-08-12 12:41:32.418 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 187
2017-08-12 12:44:36.956 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 185
2017-08-12 12:47:41.014 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 229
2017-08-12 12:50:45.152 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 229 to 190
2017-08-12 12:53:49.216 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 190 to 186
2017-08-12 12:56:54.376 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 186 to 185
2017-08-12 12:59:58.364 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 186
2017-08-12 13:03:02.449 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 186 to 188
2017-08-12 13:06:06.563 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 188 to 189
2017-08-12 13:09:10.704 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 158
2017-08-12 13:12:14.849 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 184
2017-08-12 13:15:19.024 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 184 to 188
2017-08-12 13:18:23.104 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 188 to 187
2017-08-12 13:21:27.302 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 185
2017-08-12 13:24:31.472 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 188
2017-08-12 13:27:35.593 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 188 to 189
2017-08-12 13:30:39.705 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 193
2017-08-12 13:33:43.717 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 193 to 189
2017-08-12 13:39:52.027 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 188
2017-08-12 13:42:56.150 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 188 to 179
2017-08-12 13:46:00.300 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 185
2017-08-12 13:49:04.402 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 187
2017-08-12 13:55:13.555 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 167
2017-08-12 13:58:17.768 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 191
2017-08-12 14:01:21.874 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 191 to 181
2017-08-12 14:04:26.013 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 173
2017-08-12 14:07:30.209 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 173 to 185
2017-08-12 14:13:38.458 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 187
2017-08-12 14:16:42.496 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 187 to 183
2017-08-12 14:19:46.630 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 172
2017-08-12 14:22:50.796 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 172 to 185
2017-08-12 14:25:54.952 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 181
2017-08-12 14:28:59.125 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 189
2017-08-12 14:32:03.252 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 189 to 183
2017-08-12 14:38:12.026 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 181
2017-08-12 14:41:16.087 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 183
2017-08-12 14:44:20.211 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 195
2017-08-12 14:47:24.276 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 195 to 197
2017-08-12 14:50:28.447 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 197 to 185
2017-08-12 14:53:33.431 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 192
2017-08-12 14:56:37.562 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 192 to 183
2017-08-12 14:59:41.556 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 181
2017-08-12 15:02:45.700 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 186
2017-08-12 15:05:49.870 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 186 to 183
2017-08-12 15:08:54.007 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 184
2017-08-12 15:11:58.115 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 184 to 183
2017-08-12 15:15:02.213 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 177
2017-08-12 15:18:06.354 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 177 to 180
2017-08-12 15:21:10.457 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 180 to 175
2017-08-12 15:24:14.566 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 182
2017-08-12 15:27:18.732 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 182 to 184
2017-08-12 15:30:22.859 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 184 to 181
2017-08-12 15:33:26.982 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 176
2017-08-12 15:36:31.107 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 176 to 182
2017-08-12 15:39:35.271 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 182 to 175
2017-08-12 15:42:39.335 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 193
2017-08-12 15:45:43.471 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 193 to 179
2017-08-12 15:48:47.460 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 183
2017-08-12 15:54:56.603 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 174
2017-08-12 15:58:00.788 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 174 to 182
2017-08-12 16:01:05.326 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 182 to 181
2017-08-12 16:04:09.487 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 180
2017-08-12 16:10:17.759 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 180 to 173
2017-08-12 16:13:21.913 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 173 to 175
2017-08-12 16:16:26.434 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 181
2017-08-12 16:19:30.601 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 181 to 183
2017-08-12 16:22:34.766 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 178
2017-08-12 16:25:38.910 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 178 to 173
2017-08-12 16:28:42.988 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 173 to 180
2017-08-12 16:31:47.141 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 180 to 178
2017-08-12 16:34:51.225 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 178 to 171
2017-08-12 16:37:55.365 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 171 to 175
2017-08-12 16:50:12.832 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 172
2017-08-12 16:53:16.880 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 172 to 175
2017-08-12 16:56:21.012 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 179
2017-08-12 16:59:25.196 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 166
2017-08-12 17:02:29.233 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 171
2017-08-12 17:08:37.563 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 171 to 169
2017-08-12 17:11:41.728 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 169 to 163
2017-08-12 17:14:45.842 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 166
2017-08-12 17:17:49.981 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 166 to 163
2017-08-12 17:20:54.197 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 170
2017-08-12 17:23:58.382 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 170 to 171
2017-08-12 17:27:02.522 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 171 to 155
2017-08-12 17:30:06.654 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 157
2017-08-12 17:33:10.843 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 154
2017-08-12 17:36:14.998 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 154 to 155
2017-08-12 17:39:19.114 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 158
2017-08-12 17:42:23.296 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 163
2017-08-12 17:45:27.446 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 163 to 159
2017-08-12 17:48:32.407 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 159 to 141
2017-08-12 17:51:36.600 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 141 to 156
2017-08-12 17:54:40.672 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 164
2017-08-12 17:57:44.793 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 169
2017-08-12 18:00:48.933 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 169 to 177
2017-08-12 18:03:53.055 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 177 to 126
2017-08-12 18:06:57.184 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 126 to 164
2017-08-12 18:10:01.347 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 164 to 161
2017-08-12 18:13:05.499 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 161 to 158
2017-08-12 18:16:09.551 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 158 to 113
2017-08-12 18:19:14.089 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 113 to 140
2017-08-12 18:22:18.221 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 140 to 155
2017-08-12 18:25:22.392 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 155 to 138
2017-08-12 18:28:26.535 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 138 to 129
2017-08-12 18:31:30.712 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 129 to 135
2017-08-12 18:34:34.880 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 135 to 143
2017-08-12 18:37:39.007 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 143 to 147
2017-08-12 18:40:43.122 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 146
2017-08-12 18:43:47.317 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 146 to 139
2017-08-12 18:46:52.224 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 139 to 141
2017-08-12 18:53:00.594 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 141 to 153
2017-08-12 18:56:04.720 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 153 to 146
2017-08-12 18:59:08.829 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 146 to 162
2017-08-12 19:02:12.947 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 167
2017-08-12 19:05:17.039 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 167 to 142
2017-08-12 19:08:21.146 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 142 to 144
2017-08-12 19:11:25.238 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 144 to 135
2017-08-12 19:14:29.344 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 135 to 132
2017-08-12 19:17:33.484 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 132 to 136
2017-08-12 19:20:37.589 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 136 to 124
2017-08-12 19:23:41.652 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 124 to 120
2017-08-12 19:26:45.719 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 120 to 122
2017-08-12 19:29:49.826 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 122 to 131
2017-08-12 19:32:54.027 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 131 to 112
2017-08-12 19:35:58.199 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 112 to 121
2017-08-12 19:39:02.322 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 121 to 131
2017-08-12 19:42:07.287 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 131 to 94
2017-08-12 19:45:12.236 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 94 to 107
2017-08-12 19:48:16.363 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 107 to 95
2017-08-12 19:51:20.514 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 95 to 93
2017-08-12 19:54:24.678 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 93 to 113
2017-08-12 19:57:28.855 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 113 to 96
2017-08-12 20:00:32.995 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 96 to 157
2017-08-12 20:03:37.135 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 157 to 94
2017-08-12 20:06:41.305 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 94 to 103
2017-08-12 20:09:45.464 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 103 to 104
2017-08-12 20:12:49.542 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 104 to 87
2017-08-12 20:15:54.155 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 87 to 88
2017-08-12 20:22:02.396 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 88 to 100
2017-08-12 20:25:06.441 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 100 to 94
2017-08-12 20:28:10.568 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 94 to 72
2017-08-12 20:31:14.708 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 72 to 80
2017-08-12 20:34:18.789 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 80 to 2
2017-08-12 20:37:23.777 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 83
2017-08-12 20:40:27.866 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 83 to 69
2017-08-12 20:43:32.886 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 69 to 2
2017-08-12 20:46:37.051 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 74
2017-08-12 20:49:41.186 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 74 to 47
2017-08-12 20:52:45.306 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 47 to 41
2017-08-12 20:55:49.435 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 41 to 59
2017-08-12 20:58:53.575 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 59 to 77
2017-08-12 21:01:57.673 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 77 to 55
2017-08-12 21:05:01.834 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 55 to 33
2017-08-12 21:08:06.011 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 33 to 39
2017-08-12 21:11:10.128 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 39 to 57
2017-08-12 21:14:14.243 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 57 to 55
2017-08-12 21:17:18.358 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 55 to 76
2017-08-12 21:20:22.498 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 76 to 50
2017-08-12 21:23:27.030 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 50 to 3
2017-08-12 21:26:31.145 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 3 to 78
2017-08-12 21:29:35.295 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 78 to 2
2017-08-12 21:32:39.448 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 12
2017-08-12 21:35:43.558 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 12 to 25
2017-08-12 21:38:48.119 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 25 to 73
2017-08-12 21:41:52.143 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 73 to 179
2017-08-12 21:44:56.277 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 165
2017-08-12 21:48:00.368 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 165 to 180
2017-08-12 21:54:08.686 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 180 to 174
2017-08-12 21:57:12.770 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 174 to 183
2017-08-12 22:00:16.826 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 175
2017-08-12 22:03:20.939 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 71
2017-08-12 22:06:25.045 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 47
2017-08-12 22:09:29.136 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 47 to 53
2017-08-12 22:12:33.251 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 53 to 28
2017-08-12 22:15:37.408 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 28 to 37
2017-08-12 22:18:41.522 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 37 to 98
2017-08-12 22:21:45.658 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 98 to 91
2017-08-12 22:24:49.753 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 91 to 37
2017-08-12 22:27:53.923 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 37 to 43
2017-08-12 22:30:58.032 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 43 to 45
2017-08-12 22:34:02.113 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 45 to 29
2017-08-12 22:37:06.235 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 29 to 30
2017-08-12 22:40:10.351 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 30 to 27
2017-08-12 22:43:14.451 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 27 to 2
2017-08-12 22:58:35.340 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 52
2017-08-12 23:01:39.478 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 52 to 2
2017-08-13 00:49:05.445 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 4
2017-08-13 00:52:09.532 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 4 to 2
2017-08-13 01:32:03.340 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 2 to 3
2017-08-13 01:35:07.475 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 3 to 44
2017-08-13 01:38:11.642 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 44 to 55
2017-08-13 01:41:15.715 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 55 to 71
2017-08-13 01:44:19.882 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 80
2017-08-13 01:47:24.021 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 80 to 84
2017-08-13 01:49:38.779 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 84 to 59
2017-08-13 01:52:42.160 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 59 to 76
2017-08-13 01:55:46.327 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 76 to 71
2017-08-13 01:58:50.469 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 78
2017-08-13 02:01:54.605 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 78 to 71
2017-08-13 02:04:58.758 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 89
2017-08-13 02:08:02.952 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 89 to 90
2017-08-13 02:11:07.014 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 90 to 92
2017-08-13 02:14:11.187 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 92 to 104
2017-08-13 02:17:15.356 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 104 to 98
2017-08-13 02:20:19.444 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 98 to 93
2017-08-13 02:23:23.586 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 93 to 99
2017-08-13 02:26:27.732 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 99 to 82
2017-08-13 02:29:34.029 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 82 to 81
2017-08-13 02:32:38.982 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 81 to 95
2017-08-13 02:35:43.116 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 95 to 87
2017-08-13 02:38:47.227 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 87 to 86
2017-08-13 02:41:51.681 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 86 to 71
2017-08-13 02:44:57.978 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 54
2017-08-13 02:48:02.076 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 54 to 32
2017-08-13 02:51:06.225 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 32 to 60
2017-08-13 02:54:10.319 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 60 to 51
2017-08-13 02:57:14.537 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 51 to 63
2017-08-13 03:00:18.717 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 63 to 77
2017-08-13 03:03:22.865 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 77 to 88
2017-08-13 03:06:27.089 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 88 to 73
2017-08-13 03:09:31.192 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 73 to 61
2017-08-13 03:12:35.295 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 61 to 67
2017-08-13 03:15:39.494 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 67 to 53
2017-08-13 03:18:43.659 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 53 to 65
2017-08-13 03:21:47.832 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 65 to 68
2017-08-13 03:24:51.922 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 68 to 60
2017-08-13 03:27:56.052 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 60 to 65
2017-08-13 03:31:00.245 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 65 to 76
2017-08-13 03:34:04.422 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 76 to 57
2017-08-13 03:37:08.580 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 57 to 83
2017-08-13 03:40:12.748 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 83 to 97
2017-08-13 03:43:16.868 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 97 to 70
2017-08-13 03:46:20.979 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 70 to 62
2017-08-13 03:49:25.115 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 62 to 71
2017-08-13 03:52:29.243 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 71 to 66
2017-08-13 03:55:33.344 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 66 to 72
2017-08-13 03:58:37.480 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 72 to 49
2017-08-13 04:01:41.639 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 49 to 63
2017-08-13 04:04:45.815 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 63 to 62
2017-08-13 04:07:49.909 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 62 to 73
2017-08-13 04:10:54.049 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 73 to 59
2017-08-13 04:13:58.148 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 59 to 62
2017-08-13 04:17:02.259 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 62 to 53
2017-08-13 04:20:06.465 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 53 to 48
2017-08-13 04:23:10.483 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 48 to 65
2017-08-13 04:26:14.679 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 65 to 59
2017-08-13 04:29:18.860 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 59 to 60
2017-08-13 04:32:22.995 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 60 to 67
2017-08-13 04:35:27.174 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 67 to 55
2017-08-13 04:38:31.308 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 55 to 57
2017-08-13 04:41:35.481 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 57 to 55
2017-08-13 04:44:39.626 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 55 to 61
2017-08-13 04:47:43.761 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 61 to 67
2017-08-13 04:50:47.878 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 67 to 47
2017-08-13 04:53:52.041 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 47 to 77
2017-08-13 04:56:56.217 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 77 to 69
2017-08-13 05:00:00.377 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 69 to 77
2017-08-13 05:03:04.525 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 77 to 57
2017-08-13 05:06:08.693 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 57 to 46
2017-08-13 05:09:12.844 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 46 to 70
2017-08-13 05:12:16.910 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 70 to 68
2017-08-13 05:15:21.062 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 68 to 70
2017-08-13 05:18:25.198 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 70 to 67
2017-08-13 05:21:29.300 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 67 to 63
2017-08-13 05:24:33.420 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 63 to 82
2017-08-13 05:27:37.571 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 82 to 65
2017-08-13 05:30:41.660 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 65 to 64
2017-08-13 05:33:45.767 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 64 to 53
2017-08-13 05:36:49.875 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 53 to 70
2017-08-13 05:39:53.950 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 70 to 67
2017-08-13 05:42:58.134 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 67 to 63
2017-08-13 05:46:02.260 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 63 to 72
2017-08-13 05:49:06.367 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 72 to 75
2017-08-13 05:52:10.491 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 75 to 66
2017-08-13 05:55:14.603 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 66 to 72
2017-08-13 05:58:18.670 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 72 to 58
2017-08-13 06:01:22.818 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 58 to 68
2017-08-13 06:04:26.980 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 68 to 73
2017-08-13 06:07:31.160 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 73 to 72
2017-08-13 06:13:39.502 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 72 to 75
2017-08-13 06:16:43.642 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 75 to 70
2017-08-13 06:19:47.755 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 70 to 69
2017-08-13 06:22:51.886 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 69 to 78
2017-08-13 06:25:55.987 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 78 to 97
2017-08-13 06:29:00.120 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 97 to 81
2017-08-13 06:32:04.215 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 81 to 134
2017-08-13 06:35:08.314 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 134 to 106
2017-08-13 06:38:12.542 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 106 to 84
2017-08-13 06:41:16.608 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 84 to 118
2017-08-13 06:44:20.726 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 118 to 139
2017-08-13 06:47:24.836 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 139 to 123
2017-08-13 06:50:28.958 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 123 to 115
2017-08-13 06:53:33.072 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 115 to 148
2017-08-13 06:56:37.180 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 148 to 149
2017-08-13 06:59:41.292 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 149 to 162
2017-08-13 07:02:45.428 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 162 to 147
2017-08-13 07:05:49.457 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 147 to 156
2017-08-13 07:08:53.532 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 156 to 175
2017-08-13 07:11:57.700 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 196
2017-08-13 07:15:02.246 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 179
2017-08-13 07:18:06.399 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 179 to 175
2017-08-13 07:21:10.609 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 175 to 176
2017-08-13 07:24:14.765 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 176 to 183
2017-08-13 07:27:18.843 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 183 to 174
2017-08-13 07:30:22.969 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 174 to 190
2017-08-13 07:36:31.226 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 190 to 191
2017-08-13 07:39:35.377 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 191 to 185
2017-08-13 07:42:39.433 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 185 to 190
2017-08-13 07:45:43.546 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 190 to 188
2017-08-13 07:48:47.735 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 188 to 192
2017-08-13 07:51:51.866 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 192 to 190
2017-08-13 07:54:56.022 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 190 to 193
2017-08-13 07:58:00.183 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 193 to 199
2017-08-13 08:01:04.256 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 199 to 193
2017-08-13 08:04:08.352 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 193 to 196
2017-08-13 08:07:12.463 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 193
2017-08-13 08:10:16.606 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 193 to 198
2017-08-13 08:13:20.709 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 198 to 196
2017-08-13 08:16:24.839 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 200
2017-08-13 08:22:33.031 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 200 to 201
2017-08-13 08:25:37.095 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 201 to 196
2017-08-13 08:28:41.185 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 200
2017-08-13 08:31:45.360 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 200 to 204
2017-08-13 08:34:49.528 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 204 to 255
2017-08-13 08:37:53.587 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 255 to 200
2017-08-13 08:40:57.726 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 200 to 196
2017-08-13 08:44:01.855 [ItemStateChangedEvent     ] - mstrbdrmwindowbattery changed from 196 to 2
So it starts with a value of 182....and just seems to be all over the place. Goes down to <10...then all the way back up into the 200's.
I've seen another circuit with a capacitor in the mix....need to go pick up some parts to try it.
Does anyone else have a good circuit for monitoring the lipo battery?
I'm using a Huzzah Feather with door sensor attached...added the battery monitoring circuit from the link above.
The lip battery im using is a 3.7V 1200mAh
thanks
