Variable stops passing to function
PostPosted: Fri Sep 01, 2017 3:59 pm
by murrayc2000
I have a sketch based on IOT Manager5 which reads a PIN on the NodeMCU sets a global variable to a string and then publishes this to CloudMQTT every 7 seconds for IOT manager to read. It seems to work perfectly for just over an hour. However just after that it seems to stop sending the string to an external function that generates the MQTT payload. all I get is a 1 instead of the string. My code is below... Any ideas why it stops passing the string (OPEN/CLOSED and wifistren)?
Code: Select all#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <MQTT.h>
#include <PubSubClient.h>
//#include <PubSubClient_JSON.h>
#include <ArduinoJson.h>
#include <Arduino.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//#include "WemoSwitch.h"
//#include "WemoManager.h"
#include "CallbackFunction.h"
#define GATE                            2
#define GATESTATE                       12
#define DOOROPEN                        0
#define DOORCLOSE                       4
#define DOORSTATE                       5
//on/off callbacks
/*void GarageOn();
void GarageOff();
void GatesOn();
void GatesOff();*/
 IoT Manager mqtt device client https://play.google.com/store/apps/details?id=ru.esp8266.iotmanager
 Based on Basic MQTT example with Authentication
 PubSubClient library v 1.91.1 https://github.com/Imroy/pubsubclient
  - connects to an MQTT server, providing userdescr and password
  - subscribes to the topic "/IoTmanager" (waiting "HELLO" messages from mobile device)
  - publishes config to the topic "/IoTmanager/config/deviceID/"
  Tested with Arduino IDE 1.6.7 + ESP8266 Community Edition v 2.1.0-rc2
  ArduinoJson library 5.0.7 https://github.com/bblanchon/ArduinoJson
  sketch version : 1.0
  IoT Manager    : 1.4.7 and above
  simple-btn widget demo, for details look at Widgets Guide on IoT Manager
<div class="class1" style="style1">
  <div class="class2" style="style2">
     descr
  </div>
  <button class="class3" style="style3">
    title
  </button>
</div>
String prefix   = "/IoTmanager";      // global prefix for all topics - must be some as mobile device
String deviceID="YardESP";
String PUBclientID;
String DOORPOS;
String wifistren;
long wifistr;
OneWire  ds(14);
DallasTemperature sensors(&ds);
float temp;
static unsigned long lastupdate = millis();
WiFiClient wclient;
WiFiManager wifiManager;
/*WemoManager wemoManager;
WemoSwitch *Garage = NULL;
WemoSwitch *Gates = NULL;*/
// config for cloud mqtt broker by DNS hostname ( for example, cloudmqtt.com use: m20.cloudmqtt.com - EU )
String mqttServerName = "m21.cloudmqtt.com";            // for cloud broker - by hostname, from CloudMQTT account data
int    mqttport = zzzzz;                                // default 1883, but CloudMQTT.com use other, for example: 13191, 23191 (SSL), 33191 (WebSockets) - use from CloudMQTT account data
String mqttuser =  "xxxxxxx";                              // from CloudMQTT account data
String mqttpass =  "yyyyyyyyy";                              // from CloudMQTT account data
PubSubClient client(wclient, mqttServerName, mqttport); // for cloud broker - by hostname
// config for local mqtt broker by IP address
//IPAddress server(192, 168, 1, 100);                        // for local broker - by address
//int    mqttport = 9001;                                    // default 1883, but WebSockets port needed
//String mqttuser =  "";                                     // from broker config
//String mqttpass =  "";                                     // from broker config
//PubSubClient client(wclient, server, mqttport);            // for local broker - by address
int freeheap;
const int nWidgets = 15; // number of widgets
String sTopic      [nWidgets];
String stat        [nWidgets];
String thing_config[nWidgets];
DynamicJsonBuffer jsonBuffer;
JsonObject& json_status = jsonBuffer.createObject();
void FreeHEAP() {
  if ( ESP.getFreeHeap() < freeheap ) {
    if ( ( freeheap != 100000) ) {
       Serial.print("Memory leak detected! old free heap = ");
       Serial.print(freeheap);
       Serial.print(", new value = ");
       Serial.println(ESP.getFreeHeap());
    freeheap = ESP.getFreeHeap();
String setStatus ( String s ) {
  json_status["status"] = s;
  String string_status;
  json_status.printTo(string_status);
  Serial.print("Status String is: ");
  Serial.println(string_status);
  return string_status;
String setStatus ( int s ) {
  Serial.print("Status int is: ");
void initVar() {
  PUBclientID = String( ESP.getChipId() ) + "-" + String( ESP.getFlashChipId() );     // IoT thing device ID - unique device id in our project
  // widget0
  JsonObject& root = jsonBuffer.createObject();
  sTopic[0] = prefix + "/" + deviceID + "/Garage_status0";
  root["id"] = 0;
  root["page"] = "Yard";
  root["pageId"] = "10";
  root["widget"] = "anydata";
  root["class1"] = "no-border text-center col-xs-6";                          // class for 1st div
  root["style1"] = "";                                        // style for 1st div
  root["descr"]  = "Garage Position:";                               // text  for description
  root["class2"] = "calm";                                // class for description from Widgets Guide - Color classes
  root["style2"] = "font-size:20px;float:top;padding-bottom:10px;font-weight:bold;"; // style for description
  root["topic"] = sTopic[0];
  root["class3"] = "button button-calm icon ion-model-s"; // class for button
  root["style3"] = "float:left;";                            // style for button
  root.printTo(thing_config[0]);
  // widget1
  JsonObject& root1 = jsonBuffer.createObject();
  sTopic[1] = prefix + "/" + deviceID + "/Wifi_RSSI1";
  root1["id"] = 1;
  root1["page"] = "Yard";
  root1["pageId"] = "10";
  root1["widget"] = "anydata";
  root1["class1"] = "no-border text-center col-xs-6";                          // class for 1st div
  root1["style1"] = "";                                        // style for 1st div
  root1["descr"]  = "WiFi Strength:";                       // text  for description
  root1["class2"] = "royal";                               // class for description from Widgets Guide - Color classes
  root1["style2"] = "font-size:20px;float:top;padding-bottom:10px;font-weight:bold;"; // style for description
  root1["topic"] = sTopic[1];
  root1["class3"] = "button button-royal icon ion-wifi"; // class for button
  root1["style3"] = "float:right;";                            // style for button
  root1.printTo(thing_config[1]);
  // widget2
  JsonObject& root2 = jsonBuffer.createObject();
  sTopic[2] = prefix + "/" + deviceID + "/Garage_open2";
  root2["id"] = 2;
  root2["page"] = "Yard";
  root2["pageId"] = "10";
  root2["widget"] = "simple-btn";
  root2["class1"] = "item no-border";                          // class for 1st div
  root2["style1"] = "";                                        // style for 1st div
  root2["descr"]  = "Garage Door Open";                               // text  for description
  root2["class2"] = "balanced";                                // class for description from Widgets Guide - Color classes
  root2["style2"] = "font-size:20px;float:left;padding-top:10px;font-weight:bold;"; // style for description
  root2["topic"] = sTopic[2];
  root2["class3"] = "button button-balanced icon ion-arrow-up-a"; // class for button
  root2["style3"] = "float:right;";                            // style for button
  root2.printTo(thing_config[2]);
  // widget3
  JsonObject& root3 = jsonBuffer.createObject();
  sTopic[3] = prefix + "/" + deviceID + "/Garage_close3";
  root3["id"] = 3;
  root3["page"] = "Yard";
  root3["pageId"] = "10";
  root3["widget"] = "simple-btn";
  root3["class1"] = "item no-border";                          // class for 1st div
  root3["style1"] = "";                                        // style for 1st div
  root3["descr"]  = "Garage Door Close";                       // text  for description
  root3["class2"] = "assertive";                               // class for description from Widgets Guide - Color classes
  root3["style2"] = "font-size:20px;float:left;padding-top:10px;font-weight:bold;"; // style for description
  root3["topic"] = sTopic[3];
  root3["class3"] = "button button-assertive icon ion-arrow-down-a"; // class for button
  root3["style3"] = "float:right;";                            // style for button
  root3.printTo(thing_config[3]);
  // widget4
  JsonObject& root4 = jsonBuffer.createObject();
  sTopic[4] = prefix + "/" + deviceID + "/Gate4";
  stat  [4] = setStatus (1); // LED off at startup
  root4["id"] = 4;
  root4["page"] = "Yard";
  root4["pageId"] = "10";
  root4["descr"]  = "Gate";                   // text  for description
  root4["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root4["widget"] = "toggle";
  root4["iconClass"] = "ion-wifi";
  root4["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root4["topic"] = sTopic[4];
  root4.printTo(thing_config[4]);
  // widget5
  JsonObject& root5 = jsonBuffer.createObject();
  JsonObject& cfg5 = jsonBuffer.createObject();
  sTopic[5] = prefix + "/" + deviceID + "/5BMP180_temp5";
  root5["id"] = 5;
  root5["page"] = "Yard";
  root5["pageId"] = "10";
  root5["widget"] = "steel";
  //root5["class1"] = "item no-border";
  root5["descr"]  = "Yard Temperature (°C)";                            // text  for description
  root5["topic"] = sTopic[5];
  cfg5["titleString"]  = "Yard Temperature (°C)";
  cfg5["unitString"]  = "°C";
  cfg5["width"]  = "auto";
  cfg5["BackgroundColor"]  = "CARBON";
  cfg5["gaugeType"]  = "TYPE2";
  cfg5["type"]  = "Linear";
  cfg5["lcdDecimals"]  = "2";
  cfg5["height"]  = "140";
  cfg5["FrameDesign"] = "GLOSSY_METAL";
  cfg5["lcdVisable"]  = true;
  cfg5["ColorDef"]  = "RAITH";
  cfg5["LcdColor"]  = "RED_DARKRED";
  cfg5["LedColor"]  = "MAGENTA_LED";
  cfg5["threshold"]  = 20;
  root5["widgetConfig"] = cfg5;
  root5.printTo(thing_config[5]);
  // widget6
  JsonObject& root6 = jsonBuffer.createObject();
  sTopic[6] = prefix + "/" + deviceID + "/HLight";
  stat  [6] = setStatus (1); // LED off at startup
  root6["id"] = 6;
  root6["page"] = "House";
  root6["pageId"] = "20";
  root6["descr"]  = "Hall Light";                   // text  for description
  root6["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root6["widget"] = "toggle";
  //root4["iconClass"] = "ion-wifi";
  root6["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root6["topic"] = sTopic[6];
  root6.printTo(thing_config[6]);
    // widget7
  JsonObject& root7 = jsonBuffer.createObject();
  sTopic[7] = prefix + "/" + deviceID + "/Hlight_B";
  stat  [7] = setStatus (1); // LED off at startup
  root7["id"] = 7;
  root7["page"] = "House";
  root7["pageId"] = "20";
  //root7["descr"]  = "Hall Light Brightness";                   // text  for description
  //root7["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root7["widget"] = "range";
  root7["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root7["topic"] = sTopic[7];
  root7["debounce"]  = 600;
  root7.printTo(thing_config[7]);
    // widget8
  JsonObject& root8 = jsonBuffer.createObject();
  sTopic[8] = prefix + "/" + deviceID + "/Light1";
  stat  [8] = setStatus (1); // LED off at startup
  root8["id"] = 8;
  root8["page"] = "House";
  root8["pageId"] = "20";
  root8["descr"]  = "Liv Light 1";                   // text  for description
  root8["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root8["widget"] = "toggle";
  root8["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root8["topic"] = sTopic[8];
  root8.printTo(thing_config[8]);
    // widget9
  JsonObject& root9 = jsonBuffer.createObject();
  sTopic[9] = prefix + "/" + deviceID + "/light1_B";
  stat  [9] = setStatus (1); // LED off at startup
  root9["id"] = 9;
  root9["page"] = "House";
  root9["pageId"] = "20";
  //root9["descr"]  = "Liv Light1 Brightness";                   // text  for description
  //root9["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root9["widget"] = "range";
  root9["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root9["topic"] = sTopic[9];
  root9["debounce"]  = 600;
  root9.printTo(thing_config[9]);
    // widget10
  JsonObject& root10 = jsonBuffer.createObject();
  sTopic[10] = prefix + "/" + deviceID + "/Light2";
  stat  [10] = setStatus (1); // LED off at startup
  root10["id"] = 10;
  root10["page"] = "House";
  root10["pageId"] = "20";
  root10["descr"]  = "Liv Light 2";                   // text  for description
  root10["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root10["widget"] = "toggle";
  root10["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root10["topic"] = sTopic[10];
  root10.printTo(thing_config[10]);
    // widget11
  JsonObject& root11 = jsonBuffer.createObject();
  sTopic[11] = prefix + "/" + deviceID + "/light2_B";
  stat  [11] = setStatus (1); // LED off at startup
  root11["id"] = 11;
  root11["page"] = "House";
  root11["pageId"] = "20";
  //root11["descr"]  = "Liv Light2 Brightness";                   // text  for description
  //root11["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root11["widget"] = "range";
  root11["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root11["topic"] = sTopic[11];
  root11["debounce"]  = 600;
  root11.printTo(thing_config[11]);
    // widget12
  JsonObject& root12 = jsonBuffer.createObject();
  sTopic[12] = prefix + "/" + deviceID + "/Light3";
  stat  [12] = setStatus (1); // LED off at startup
  root12["id"] = 12;
  root12["page"] = "House";
  root12["pageId"] = "20";
  root12["descr"]  = "Liv Light 3";                   // text  for description
  root12["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root12["widget"] = "toggle";
  root12["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root12["topic"] = sTopic[12];
  root12.printTo(thing_config[12]);
    // widget13
  JsonObject& root13 = jsonBuffer.createObject();
  sTopic[13] = prefix + "/" + deviceID + "/light3_B";
  stat  [13] = setStatus (1); // LED off at startup
  root13["id"] = 13;
  root13["page"] = "House";
  root13["pageId"] = "20";
  //root13["descr"]  = "Liv Light3 Brightness";                   // text  for description
  //root13["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root13["widget"] = "range";
  root13["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root13["topic"] = sTopic[13];
  root13["debounce"]  = 600;
  root13.printTo(thing_config[13]);
    // widget14
  JsonObject& root14 = jsonBuffer.createObject();
  sTopic[14] = prefix + "/" + deviceID + "/Heating";
  stat  [14] = setStatus (0); // LED off at startup
  root14["id"] = 14;
  root14["page"] = "House";
  root14["pageId"] = "20";
  root14["descr"]  = "Heating";                   // text  for description
  root14["descrStyle"] = "background-color:#5F9EA0;border:solid 2px #F00;font-size:20px;font-weight:bold;";
  root14["widget"] = "toggle";
  root14["color"] = "black";                     // black, blue, green, orange, red, white, yellow (off - grey)
  root14["topic"] = sTopic[14];
  root14.printTo(thing_config[14]);
  void pubStatus(String t, String payload) {
    if (client.publish(t + "/status", payload)) {
       Serial.println("Publish new status to " + t + "/status" + ", value: " + payload);
    } else {
       Serial.println("Publish new status to " + t + "/status" + " FAIL!");
       client.disconnect();
    yield();
    FreeHEAP(); // check memory leak
  void pubConfig() {
  bool success;
  bool success2;
    success2 = client.publish(MQTT::Publish(prefix + "/" + deviceID + "/response", "{\"pages\":[{\"pageId\": 10, \"pageName\": \"Yard\"},{\"pageId\": 20, \"pageName\": \"House\"}]}").set_qos(1));
    if (success2) {
       Serial.println("Publish config: Success");
    } else {
       Serial.println("Publish config FAIL!");
       delay(1000);
       ESP.restart();
  for (int i = 0; i < nWidgets; i = i + 1) {
      success = client.publish(MQTT::Publish(prefix + "/" + deviceID + "/config", thing_config[i]).set_qos(1));
      if (success) {
         Serial.println("Publish config: Success (" + thing_config[i] + ")");
         Serial.println(i);
      } else {
         Serial.println("Publish config FAIL! ("    + thing_config[i] + ")");
         delay(1000);
         ESP.restart();
  char buffer[16];
  char bufferjson = '}';
  char buffertot[16];
  sprintf(buffer,"%s","{\"status\":");
  dtostrf(temp, 2, 2, &buffer[strlen(buffer)]);
  sprintf(buffertot, "%s%c", buffer, bufferjson);
  stat[5] = buffertot;//setStatus( buffer );
  Serial.println(stat[5]);
  if(digitalRead(DOORSTATE)==HIGH) {
    DOORPOS=" OPEN";
  } else {
    DOORPOS=" CLOSED";
  pubStatus(sTopic[0], setStatus(DOORPOS)); // LED off at startup
  pubStatus(sTopic[5], stat[5]);
void callback(const MQTT::Publish& sub) {
  Serial.print("Get data from subscribed topic ");
  Serial.print(sub.topic());
  Serial.print(" => ");
  Serial.println(sub.payload_string());
  if ( sub.payload_string() == "HELLO" ) {  // handshaking
     pubConfig();
  if (sub.topic() == sTopic[2] + "/control") {   // control from toggle - widget id 0 - ON
    // payload from button always 1, change status only for widget toggle - id 2
    stat[2] = setStatus(1);   // 1-on 2-off LED on phone
    digitalWrite(DOOROPEN, HIGH);   // 0-on 1-off LED on device
    pubStatus(sTopic[2], stat[2]);
 } else if (sub.topic() == sTopic[3] + "/control") {   // control from simple-btn - widget id 1 - OFF
    stat[3] = setStatus(0);  // 1-on 2-off LED on phone
    digitalWrite(DOORCLOSE, HIGH);  // 0-on 1-off LED on device
    pubStatus(sTopic[3], stat[3]);
 } else if (sub.topic() == sTopic[4] + "/control") {  // control from simple-btn - widget id 2 - ON
    if (sub.payload_string() == "0") {
       stat[4] = setStatus(0);
       digitalWrite(GATE, HIGH);
    } else {
       stat[4] = setStatus(1);
    pubStatus(sTopic[4], stat[4]);
  initVar();
  wifiManager.autoConnect("XXXXXX", "YYYYYYYYYY");
  delay(10);
  Serial.println("MQTT client started.");
  sensors.begin();
  Serial.print("Requesting temperatures...");
  sensors.requestTemperatures();
  Serial.print("Temperature for Device 1 is: ");
  Serial.println(sensors.getTempCByIndex(0));
  temp = sensors.getTempCByIndex(0);
  Serial.println(WiFi.RSSI());
  // GATE
  pinMode(GATE, OUTPUT);
  // DOOROPEN
  pinMode(DOOROPEN, OUTPUT);
  // DOORCLOSE
  pinMode(DOORCLOSE, OUTPUT);
  // DOORSTATE
  pinMode(DOORSTATE, INPUT_PULLUP);
  // GATESTATE
  pinMode(GATESTATE, INPUT_PULLUP);
  /*wemoManager.begin();
  // Format: Alexa invocation name, local port no, on callback, off callback
  Garage = new WemoSwitch("Garage Door", 80, GarageOn, GarageOff);
  Gates = new WemoSwitch("Gates", 81, GatesOn, GatesOff);
  wemoManager.addDevice(*Garage);
  wemoManager.addDevice(*Gates);*/
  FreeHEAP();
  freeheap = 100000;
  if (WiFi.status() != WL_CONNECTED) {
   ESP.restart();
  if (WiFi.status() == WL_CONNECTED) {
      if (!client.connected()) {
      Serial.println("Connecting to MQTT server ...");
      bool success;
      if (mqttuser.length() > 0) {
        success = client.connect( MQTT::Connect( PUBclientID ).set_auth(mqttuser, mqttpass) );
      } else {
        success = client.connect( PUBclientID );
      if (success) {
        client.set_callback(callback);
        Serial.println("Connect to MQTT server: Success");
        client.subscribe(prefix);  // for receiving HELLO messages and handshaking
        client.subscribe(prefix + "/" + deviceID + "/+/control"); // subscribe to all "control" messages for all widgets of this device
        pubConfig();
      } else {
        Serial.println("Connect to MQTT server: FAIL");
        delay(1000);
    if (client.connected()) {
      client.loop();
  //yield();
  //wemoManager.serverLoop();
  yield();
  static unsigned long last = millis();
  if (millis() - last > 1000) {
      last = millis();
        digitalWrite(DOOROPEN, LOW);
        digitalWrite(DOORCLOSE, LOW);
        digitalWrite(GATE, LOW);
    if (millis() - lastupdate > 7000) {
      Serial.println(lastupdate);
    DOORPOS=" OPEN";
  } else {
    DOORPOS=" CLOSED";
  stat[0]=setStatus(DOORPOS);
  wifistr = WiFi.RSSI();
  Serial.println(wifistr);
  if(wifistr > -55) {
    wifistren=" Excellent";
  } else if (wifistr < -55 & wifistr > -65) {
    wifistren=" Very Good";
  } else if (wifistr < -65 & wifistr > -70) {
    wifistren=" Okay";
  } else if (wifistr < -70 & wifistr > -80) {
    wifistren=" Not Good";
  } else {
    wifistren=" Unuseable";
  Serial.println(DOORPOS);
  Serial.println(wifistren);
  stat[1]=setStatus(wifistren);
  stat[4] = setStatus(digitalRead(GATESTATE));
  Serial.println(stat[0]);
  Serial.println(stat[1]);
  char buffer[16];
  char buffertot[16];
  if(temp < 20){
    thing_config[5].replace("ColorDef\":\"RED", "ColorDef\":\"RAITH");
    client.publish(MQTT::Publish(prefix + "/" + deviceID + "/config", thing_config[5]).set_qos(1));
  Serial.println(thing_config[5]);
  } else {
    thing_config[5].replace("ColorDef\":\"RAITH", "ColorDef\":\"RED");
  for (int i = 0; i < 6; i = i + 1) {
    pubStatus(sTopic[i], stat[i]);
/*void GarageOn() {
    Serial.print("Garage Open Relay turn on ...");
void GarageOff() {
    Serial.print("Garage Close Relay turn on ...");
void GatesOn() {
    Serial.print("Gate Reley turn on ...");
void GatesOff() {
    Serial.print("Gate Relay turn on ...");
Re: Variable stops passing to function
PostPosted: Sun Sep 03, 2017 5:07 pm
by murrayc2000
Both the iot manager app on my phone starts saying door position is 1 instead of closed and the serial connection reports what it's publishing to cloud mqtt is 1 instead of open or closed.
PostPosted: Fri Sep 08, 2017 6:07 am
by murrayc2000
I guess my previous reply has got lost in the post. Sorry. When I look on my IOT Manager app on my phone the data/widget shows as 1 rather than "open" or "closed" and in my serial terminal it says what it is sending to MQTT is {"status": 1} which is what MQTT says it receives. so not sure why when I send the value of the variable as "open" or "closed" it comes back as 1. It does this with the wifi strength too? I have a serial print of the variable and it says the variable is either "open" or "closed".
Thanks
