Here's the error I'm getting:
Arduino: 1.8.4 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\phil\AppData\Local\Arduino15\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\phil\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\phil\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\phil\AppData\Local\Temp\arduino_build_90382 -warnings=none -build-cache C:\Users\phil\AppData\Local\Temp\arduino_cache_412248 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\esp8266\examples\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\phil\AppData\Local\Arduino15\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\phil\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.7.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\phil\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\phil\AppData\Local\Temp\arduino_build_90382 -warnings=none -build-cache C:\Users\phil\AppData\Local\Temp\arduino_cache_412248 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\esp8266\examples\Blink\Blink.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\phil\AppData\Local\Temp\arduino_build_90382/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\phil\AppData\Local\Temp\arduino_build_90382\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Users\phil\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\phil\AppData\Local\Temp\arduino_build_90382/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\phil\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\phil\AppData\Local\Temp\arduino_build_90382\sketch\Blink.ino.cpp" -o "C:\Users\phil\AppData\Local\Temp\arduino_build_90382\preproc\ctags_target_for_gcc_minus_e.cpp"
exit status -1073741515
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
I've completely uninstalled the IDE, deleted all Arduino folders, reinstalled, reinstalled the 8266 board from board manager, selected the NodeMCU 1.0 board from board manager, and still get the same compile error when compiling the simple blink example sketch. I'm installing the IDE from the windows store.
I've set windows to view hidden files and still don't see the Arduino15 folders in the Local\Packages\Arduino15 even though it's referenced all over the log.
I do have C:\Users\phil\AppData\Local\Packages\ArduinoLLC.ArduinoIDE_mdqgnx93n4wtt and C:\Users\phil\Documents\Arduino. These are the two location I deleted before the reinstall.
Can anyone point me in the right direction to get my IDE working again?
