- Sun Sep 03, 2017 12:48 am
#69695
No error. Just fail..
I did some more reading and noticed that the library just drops the message. Then I felt a bit embarrassing to read from github page:
The maximum message size, including header, is 128 bytes by default. This is configurable via MQTT_MAX_PACKET_SIZE in PubSubClient.h.
woops. Anyhow, ran into next problem. It didn't work even if I included this.
It was after the #include so of course wouldn't work but it didn't work the other way around either. Then I increased the value directly in the arduino library .h file. Then it works as I expected.
It is defined like this in the .h file. It was 128 but I have increased it.
Code: Select all// MQTT_MAX_PACKET_SIZE : Maximum packet size
#ifndef MQTT_MAX_PACKET_SIZE
#define MQTT_MAX_PACKET_SIZE 328
#endif Why it didn't work with the #define before #include?
The ESP is reading JSON from Arduino. Basically it is just message handler between Arduino and MQTT server. Any comments on my code appreciated!
Code: Select all#define MQTT_VERSION MQTT_VERSION_3_1_1
#define MQTT_MAX_PACKET_SIZE 500
#include <PubSubClient.h>
#include <ArduinoJson.h>
// OTA updates start
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
// OTA updates end
// Wifi: SSID and password
const char* WIFI_SSID = "XX";
const char* WIFI_PASSWORD = "XX";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "XX";
const PROGMEM char* MQTT_SERVER_IP = "XX";
const PROGMEM uint16_t MQTT_SERVER_PORT = XX;
const PROGMEM char* MQTT_USER = "XX";
const PROGMEM char* MQTT_PASSWORD = "XX";
// MQTT: topic
const PROGMEM char* MQTT_SENSOR_TOPIC_WAREHOUSE = "warehouse/json";
// Leds
#define LEDRED 16
#define LEDGREEN 12
// Serial communication
String inputString = ""; // a string to hold incoming data
// Wifi and MQTT clients
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
//Serial.print("INFO: Attempting MQTT connection...");
// Attempt to connect
if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
//Serial.println("INFO: connected");
} else {
//Serial.print("ERROR: failed, rc=");
//Serial.print(client.state());
//Serial.println("DEBUG: try again in 5 seconds");
// Wait 5 seconds before retrying
yield();
delay(5000);
// init the serial
Serial.begin(9600);
inputString.reserve(360); // reserve 200 bytes for the inputString:
pinMode(LEDRED, OUTPUT);
pinMode(LEDGREEN, OUTPUT);
digitalWrite(LEDRED, LOW);
digitalWrite(LEDGREEN, LOW);
digitalWrite(LEDRED, HIGH);
// init the WiFi connection
//Serial.println();
//Serial.println();
//Serial.print("INFO: Connecting to ");
WiFi.mode(WIFI_STA);
//Serial.println(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
unsigned long connect_check = millis();
//Serial.print(".");
if ( connect_check + 10000 < millis() )
//Serial.println(".");
//Serial.println("Attempting to reconnect wifi");
WiFi.disconnect();
delay(1000);
yield();
Serial.println("");
Serial.println("INFO: WiFi connected");
Serial.println("INFO: IP address: ");
// init the MQTT connection
client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
client.setCallback(callback);
// OTA updates
ArduinoOTA.setHostname("xx");
ArduinoOTA.setPassword((const char *)"xx");
ArduinoOTA.onStart([]() {
Serial.println("Start");
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
digitalWrite(LEDGREEN, HIGH);
if (!client.connected()) {
reconnect();
client.loop();
ArduinoOTA.handle();
yield();
checkSerialEvent();
void checkSerialEvent() {
while (Serial.available()) {
// get the new byte:
char inChar = (char)Serial.read();
// add it to the inputString:
inputString += inChar;
// if the incoming character is a newline, set a flag
// so the main loop can do something about it:
if (inChar == '\n')
// Message has ended. Decode it.
decodeMessage();
// Decode done. Clear the input buffer
inputString = "";
void decodeMessage()
Serial.println(inputString);
char data[300];
/*StaticJsonBuffer<370> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(inputString);
const size_t bufferSize = 2*JSON_OBJECT_SIZE(1) + 2*JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(4) + 140;
DynamicJsonBuffer jsonBuffer(bufferSize);
if (!root.success())
// Return if parsing fails
strcpy(data, "{\"parse\":\"failed\"}");
client.publish(MQTT_SENSOR_TOPIC_WAREHOUSE, data, true);
return;
// Send JSON directly to MQTT
root.printTo(data, root.measureLength() + 1);
//strcpy(data, "{\"lock\":{\"state\":\"LOCK\"},\"door\":{\"state\":\"closed\"},\"temperature\":{\"warehouse\":\"20\",\"outside\":\"21\",\"sauna\":\"22\"},\"humidity\":{\"warehouse\":\"23\",\"outside\":\"24\",\"sauna\":\"25\"}}");
Serial.println(client.publish(MQTT_SENSOR_TOPIC_WAREHOUSE, data, true));
//sendMQTT(data);
void sendMQTT(char* data)
//client.publish(MQTT_SENSOR_TOPIC_WAREHOUSE, data, true);
