- Thu Sep 14, 2017 8:14 am
#69973
generic esp8266 module
flash mode: DIO
40mhz,80mhz,512k(64spiffs)
debug port serial ................ where do I view?
reset modemcu .................... how do I "factory reset?"
speed 114200
port ttyUSB1
get board info: BN: Unknown board, 10c4, ea60, sn=upload any to obtain
So last night (are you ever coming to bed
) I did get some things to work - althought I'm not sure how or why. I loaded someone's "Hello_World" (ssid) and my server saw it but wouldn't connect. Let me back up a bit. This all started with a RasPi post
http://raspi.tv/2017/wireless-remote-sensing-with-wemos-d1-mini-arduino-ide-raspberry-pi-and-lighttpd-web-server (my hot tub some times goes wonky - I go out needing a good hot soak and ^^$#^#^&%&%& 90 or less deg F) Sounded like the perfect soultion and here we are. And I'm a geek, luv a challenge, I'm KCOBLACK1, RasPi controlled hydroponic greenhouse.
I did find out - after uploading something last night I tried hooking up the TMP36 - put the wire in to D0 and the blue led just off the Rst button (OH there it is) dimly blinking and fast (?100/sec) and the blue led on the WiFi chip came on
connected the Gnd and 3.3v and board led on solid. Removed wires and nothing changed - until I did another Upload - assume "resetting board". Oh, code says "Serial.print (attempting to connect..." where does that show up?
So I'm thinking ... load code, do Upload, when done - I hit the Flash button? Pull up/down GPIO pin X? Rst? It's like I've got a blindfold on. I'm so close but ??????
Thanks for instructions.
