tried both 9600 and 115200. ended up viewing bootloader at 76800 and it looks like i'm getting a checksum error.
any idea how to fix this? both boards same problem.
Explore... Chat... Share...
rudy wrote:Most likely is that you have a power problem. The 3.3v supply must be capable of supplying 500mA on peaks. If you are powering the ESP from the FDTI's 3.3v then that is your problem.
