By Wojtek
#71490 Hi,
I have ESP8266 12-E (ai-thinker) module which have erased flash. Serial monitor (baud 74880) is showing (with GPIO00 connected to GND)
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(1,7)
and (with GPIO00 floating)
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,7)
ets_main.c
For sure serial connection and power supply is OK.
Could you please recommend any working and up-to-date tutorial showing how to upload new firmware into flash and use ESP with Arduino IDE?
PS. Sorry for my english.
By schufti
#71503 1st) redo the soldering. The solder job on pins and the module look pretty "dry".
2nd) use reccomended pullup's on gpio0/2, chpd and pulldown on gpio15.
allthough there are resistors on the board for chpd and gpio15 I had some of these adapters where the resistors had useless values (50k). I usually use 4k7.
By Wojtek
#71578
schufti wrote:1st) redo the soldering. The solder job on pins and the module look pretty "dry".
Thanks for your reply. Unfotunately still the same symptoms.
1) Boot in normal mode (baud 74880):
2) Boot in normal mode (baud 115200):
3) Boot in flash mode (baud 74880):
I've redone soldering (hope it looks better now):
I've checked also resistors. R1 and R3 are both 10kOhm. R2 is not used.
philbowles wrote:...or buy a Wemos D1...
Maybe it's a solution. But my ai-thinker 12-E should work too.
Circuit like that was working well few days ago. Now I'm almost sure that problem is with wrong firmware, but I can't find any instruct how to upload right firmware.
By Wojtek
#71604
I'am almost sure that circuit and power supply are OK. Especially it worked few days ago. I have absolutely no idea why it doesn't work now.
After upload any sketch via Arduino IDE serial monitor looks like:
Of course maybe it's the simplest solution. But I just want to try fix that module... it will work... I hope ;)
Any other ideas?
