3V3 --> VCC
RST --> GND
EN --> VCC
TX --> RX
RX --> TX
IO0 --> GND (ground for programming / 3.3V for firmware booting)
IO2 -->
GND --> GND
Certainly correct anything I have above.
RST: Much information is conflicting here. My assumption from past experience is that connecting this to 3.3V will reset the board. Can someone confirm?
RX/TX: I am currently connecting this to a sparkfun FTDI basic board. My RX--> TX and TX--> RX. I have seen many tutorials that swap these. Can someone confirm the connections to a FTDI sparkfun basic
GND: I have tried to connect the FTDI ground directly to GND on the ESPP8266. I have read there have been issues with this and that you need a common ground. I have added a separate 1A power supply @ 3.3V. I have removed the ground from the FTDI and only used the PS one as well as making a common ground between the FTDI and PS.
VCC: I have used the FTDI PS. I have read there may not be enough power to run the ESPP so I opted for the power supply to provide the 3.3V.
Now it is very possible that I have a bad ESPP8266, but I wanted to confirm that the above assumptions are correct. At this point I have never had the ESPP8266 light up to indicate power. I have another one ordered incase this is bad.
If I could get confirmation on correct hookup for normal operation, then I can make the assumptions for firmware and TX/RX.
Appreciate the help and patience.
