The first code works while in the loop but I'll be adding more code as I figure things out and would like the loop to get the timer from a void. So why does the second code not work?
const int pump = 4;
unsigned int pumpOnTime = 1;
unsigned int pumpOffTime = 2;
int pumpPowerValue = 100;
unsigned long previousMillis = 0;
unsigned long minutesPumpOn = pumpOnTime * 1000 * 60;
unsigned long minutesPumpOff = pumpOffTime * 1000 * 60;
int interval = pumpOnTime;
boolean pumpOnOffToggle = true;
pinMode(pump, OUTPUT);
analogWrite(pump, pumpPowerValue);
if ((unsigned long)(currentMillis - previousMillis) >= interval) {
if (pumpOnOffToggle) {
analogWrite (pump, 0);
interval = minutesPumpOff;
} else {
analogWrite (pump, pumpPowerValue);
interval = minutesPumpOn;
pumpOnOffToggle = !(pumpOnOffToggle);
}const int pump = 4;
void loop(){
pumpTimer;
void pumpTimer()
} else {
