Using void loops
PostPosted: Fri Nov 10, 2017 11:32 am
by Ppl39
I'm writing code so I can control a water pump with the ESP8266 12e
The first code works while in the loop but I'll be adding more code as I figure things out and would like the loop to get the timer from a void. So why does the second code not work?
Code: Select allconst int pump = 4;
unsigned int pumpOnTime = 1;
unsigned int pumpOffTime = 2;
int pumpPowerValue = 100;
unsigned long previousMillis = 0;
unsigned long minutesPumpOn = pumpOnTime * 1000 * 60;
unsigned long minutesPumpOff = pumpOffTime * 1000 * 60;
int interval = pumpOnTime;
boolean pumpOnOffToggle = true;
  pinMode(pump, OUTPUT);
  analogWrite(pump, pumpPowerValue);
  unsigned long currentMillis = millis();
  if ((unsigned long)(currentMillis - previousMillis) >= interval) {
    if (pumpOnOffToggle) {
      analogWrite (pump, 0);
      interval = minutesPumpOff;
    } else {
      analogWrite (pump, pumpPowerValue);
      interval = minutesPumpOn;
    pumpOnOffToggle = !(pumpOnOffToggle);
    previousMillis = currentMillis;
void loop(){
  pumpTimer;
void pumpTimer()
    } else {
Re: Using void loops
PostPosted: Mon Nov 13, 2017 1:16 pm
by Ppl39
After a day away I've figured it out.
