load 0x40100000, len 816, room 16
tail 0
chksum 0x8d
load 0x3ffe8000, len 788, room 8
tail 12
chksum 0xcf
ho 0 tail 12 room 4
load 0x3ffe8314, len 288, room 12
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 8Mbit
jump to run user1
( .........the above is what is output from the module with the following files installed.......then nothing...as expected,
because it is waiting for an AT command.......i tried many different baud rates to input...74880,115200,9600,6240,19200,57k
etc.....silence ...also tried many other releases ...i only want the AT commands stuff at this point, and i understand others
have same or similar issues........ )
to address 0x0000..................ESP8266_AT_Bin_V1.5.1\bin\boot_v1.2.bin
to address 0xfC000.................ESP8266_AT_Bin_V1.5.1\bin\esp_init_data_default.bin
to address 0X7E000 and 0xfe000.....ESP8266_AT_Bin_V1.5.1\bin\blank.bin
to address 0X01000.................ESP8266_AT_Bin_V1.5.1\bin\at\512+512\user1.1024.new.2.bin
................cant someone please! put a place out there with tried and sure no hunting required that wont be messed with
.....complete with the "flasher that will work , and a terminal auto baud selection.... .good old english explanation of things screenshots etc........no more standard AT or AT+RST etc videos ...and put a date on it in large print so the viewer would know not just a rehash of the same ol stuff.....and clarify the difference between chip level uart and true rs232 protocol as the drivers invert the logic as well as voltage levels....
.............is this really asking too much ? ........... then it might be a little fun..but at this point ....my position on the matters...............................what a joke !
