This is the code:
extern "C" {
#include <espnow.h>
#include <user_interface.h>
#define WIFI_DEFAULT_CHANNEL 3
#define MYMODE_CONTROLLER 0
#define MYMODE_SLAVE 1
#define ESP_BROADCAST
// First ESP8266 as controller : 0x5C,0xCF,0x7F,0xD5,0xEB,0xA8
// Second ESP8266 as slave : 0x5C,0xCF,0x7F,0xB5,0x68,0x98
uint8_t espController[] = {0x5C, 0xCF, 0x7F, 0xD5, 0xEB, 0xA8};
uint8_t espSlave[] = {0x5C, 0xCF, 0x7F, 0xB5, 0x68, 0x98};
uint8_t espBroadcast[] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
uint8_t myMode = MYMODE_CONTROLLER;
uint8_t data[1] = {0};
void printMacAddress(uint8_t* macaddr) {
Serial.print("{");
for (int i = 0; i < 6; i++) {
Serial.print("0x");
Serial.print(macaddr[i], HEX);
if (i < 5) Serial.print(',');
Serial.println("}");
bool macAddressMatch(uint8_t* mac1, uint8_t* mac2) {
bool isMatch = true;
if (mac1[i] != mac2[i]) {
isMatch = false;
break;
return isMatch;
Serial.begin(74880);
//WiFi.disconnect();
WiFi.mode(WIFI_STA);
// WiFi.mode(WIFI_AP);
// WiFi.softAP("aaa", "", WIFI_DEFAULT_CHANNEL); //strAPPwd);
if (esp_now_init() == 0) {
Serial.println("EspNow init ok");
} else {
Serial.println("EspNow init failed");
// ESP.restart();
return;
uint8_t macaddr[6];
wifi_get_macaddr(STATION_IF, macaddr);
//wifi_get_macaddr(SOFTAP_IF, macaddr);
Serial.print("Station Mac Address: ");
printMacAddress(macaddr);
if (macAddressMatch(macaddr, espController)) {
Serial.println("\nSet this device as controller");
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
#ifdef ESP_BROADCAST
int res1 = esp_now_add_peer(espBroadcast, (uint8_t)ESP_NOW_ROLE_SLAVE, WIFI_DEFAULT_CHANNEL, NULL, 0);
#else
int res1 = esp_now_add_peer(espSlave, (uint8_t)ESP_NOW_ROLE_SLAVE, WIFI_DEFAULT_CHANNEL, NULL, 0);
#endif
Serial.println("\nPeer add result " + String(res1));
} else {
Serial.println("\nSet this device as slave");
myMode = MYMODE_SLAVE;
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
int res1 = esp_now_add_peer(espBroadcast, (uint8_t)ESP_NOW_ROLE_CONTROLLER, WIFI_DEFAULT_CHANNEL, NULL, 0);
#else
int res1 = esp_now_add_peer(espController, (uint8_t)ESP_NOW_ROLE_CONTROLLER, WIFI_DEFAULT_CHANNEL, NULL, 0);
#endif
esp_now_register_recv_cb([](uint8_t *macaddr, uint8_t *data, uint8_t len) {
Serial.println("recv_cb");
Serial.print("mac address: ");
Serial.print("data: ");
for (int i = 0; i < len; i++) {
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.println("");
esp_now_register_send_cb([](uint8_t* macaddr, uint8_t status) {
Serial.print("status = "); Serial.println(status);
if (status != 0) {
Serial.println("Packet not received by ");
if (status == 0) {
Serial.println("Packet succesfull received by ");
Serial.println("");
if (myMode == MYMODE_CONTROLLER) {
data[0] = (data[0] != 0) ? 0 : 1;
esp_now_send(espBroadcast, data, 1);
#else
esp_now_send(NULL, data, 1);
#endif
delay(1000);
}and logs:
** NORMAL RUN:
------ CONTROLLER LOG (SLAVE OFF) ---------------------
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v0c897c37
~ld
EspNow init ok
Station Mac Address: {0x5C,0xCF,0x7F,0xD5,0xEB,0xA8}
Peer add result 0
status = 1
{0x5C,0xCF,0x7F,0xB5,0x68,0x98}
status = 1
status = 1
status = 1
------ CONTROLLER LOG (SLAVE ON) ---------------------
tail 8
chksum 0x2d
csum 0x2d
v0c897c37
~ld
EspNow init ok
Peer add result 0
status = 0
status = 0
status = 0
status = 0
------ SLAVE LOG (CONTROLLER ON) ---------------------
tail 8
chksum 0x2d
csum 0x2d
v0c897c37
~ld
EspNow init ok
Station Mac Address: {0x5C,0xCF,0x7F,0xB5,0x68,0x98}
Peer add result 0
recv_cb
mac address: {0x5C,0xCF,0x7F,0xD5,0xEB,0xA8}
data: 1
recv_cb
data: 0
recv_cb
data: 1
recv_cb
data: 0
** BROADCAST TEST:
------- CONTROLLER LOG ---------------------------------
tail 8
chksum 0x2d
csum 0x2d
v0c897c37
~ld
EspNow init ok
Peer add result -3
status = 0
{0xFF,0xFF,0xFF,0xFF,0xFF,0xFF}
status = 0
status = 0
status = 0
status = 0
status = 0
------ SLAVE LOG ---------------------------------------
tail 8
chksum 0x2d
csum 0x2d
v0c897c37
~ld
EspNow init ok
Peer add result -3
Thanks in advance.
