Page 1 of 2
Using screen (Ubuntu) with ESP8266
PostPosted: Wed Dec 27, 2017 1:56 pm
by rsatchel
Hi,
First time user and first time poster here. I am using Ubuntu 16.04.
My ESP8266 arrived in the mail yesterday. I found the ESP8266 as /dev/ttyUSB0 using the Arduino Serial Monitor. I pressed the Reset button on the ESP8266 and received in the Arduino Serial Monitor the message:
Code: Select allNodeMCU 0.9.5 build 20150318  powered by Lua 5.1.4
lua: cannot open init.lua
which is what I understand I am supposed to be geting.
I realise that I cannot use the Arduino Serial Monitor to send commands to the ESP8266 as the CRLF is not correct (or non-existent I believe).
So I opened a terminal and typed in:
Code: Select allscreen /dev/ttyUSB0
However screen just terminates with the message:
Code: Select all[screen is terminating]
What am I doing wrong? How can I get this to work?
Re: Using screen (Ubuntu) with ESP8266
PostPosted: Fri Dec 29, 2017 6:40 am
by cendev
Can't confirm but better try with sudo :)
PostPosted: Fri Dec 29, 2017 10:55 am
by dragondaud
in Ubuntu a user must be a member of the group 'dialout' to access serial ports. Using 'sudo' just bypasses security, and is not good practice. Add yourself to the dialout group like:
Code: Select allsudo adduser $USER dialout
You will have to logout and back in for the group change to be used.
Also, you might find 'minicom' to be a more user-friendly terminal program.
PostPosted: Fri Dec 29, 2017 8:27 pm
by rsatchel
I double checked, my username is already a member of dialout.
Also checking out minicom now.
