By Logan
#73686 Basically i'm trying to do this project (https://www.hackster.io/simpleiothings/ ... q-d-f4e1ca) with these boards (https://www.amazon.com/gp/aw/d/B01IK9GE ... _pop_mb_pd). I used ESP8266Flasher and flashed one of the boards and got it doing what I wanted pretty quickly. Now when I try to do the exact same thing on the other board, it isn't working. the first board only had the LED light up for a second when i plugged it in and then it went out, but i flashed it no problem. the problem board is keeping its LED on. when i try to flash it the flasher stays a thing "ready" and in the log it says it's bad looking for the ESP8266 even though i have the right COM port selected and everything's the same as the last board. i've tried different USB cables and reinstalling the driver but i don't know what to do, why won't it let me flash it!?
By Luiz Almeida
#73999
hortplus wrote:I had trouble with flashing and like you i tried everything. Turns out power supply was an issue. How about adding an external power source?
Hi hortplus,
What kind of power supply solved your problem?
Thank you in advance.
Regards,
LA
