Creating Software using ARDUINO IDE
PostPosted: Mon Feb 12, 2018 2:11 pm
by KurtMPU
Hello to all,
I have some problems to install software using ARDUINO IDE.
I use a nodemcu CH340G. I always have problems to execute the software.
I flashed the firmware : nodemcu_float_0.9.6-dev_20150704.bin --> this works perfect!!!
On the arduino IDE I selected nodeMCU 0.9 (ESP-12 Module).
then I compiled and loaded a program to the MCU.
writing flash
................................................................................ [ 31% ]
................................................................................ [ 62% ]
................................................................................ [ 93% ]
................ [ 100% ]
starting app without reboot
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
espcomm_send_command: receiving 2 bytes of data
closing bootloader
flush start
setting serial port timeouts to 1 ms
setting serial port timeouts to 1000 ms
flush complete
it seems evry thing is ok.
When I reboot the MPU the blue lihgt is flashing.
buuuut!!!!
there is only a funny output on the com-port:
ets Jan 8 2013,rst cause:4, boot mode:(3,1)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v4ceabea9
~ld
Whats happend?
I would be happy to get an answer soon.
Thanks
Re: Creating Software using ARDUINO IDE
PostPosted: Tue Feb 13, 2018 6:53 am
by btidey
The output you are seeing is the chip resetting due to a problem.
In this case it appears to be triggered by the built in watchdog timer. This can happen if there is a delay in your program that then prevents the background tasks from executing. One should normally aim to have the loop in the sketch cycle in under a second as the background tasks are then given CPU time.
You need to post the code you are trying to run to get more specific help.
PostPosted: Tue Feb 13, 2018 8:48 am
by rudy
Start with a known working program. Something simple, like Blink. Work out the problems then continue with the programs you are interested in.
