I have a NodeMCU V3 and my first project is to try and build a weather station.
After reading a number of tutorials I decided that a BMP280 appeared to be a perfect component for my project as it can supply temperature, barometric pressure and humidity information.
I am using the following example sketch:
Project: BME Weather Web server using NodeMCU
Implements Adafruit's sensor libraries.
Complete project is at: http://embedded-lab.com/blog/making-a-simple-weather-web-server-using-esp8266-and-bme280/
Modified code from Rui Santos' Temperature Weather Server posted on http://randomnerdtutorials.com
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme; // I2C
// Replace with your network details
const char* ssid = "SKY3E915";
const char* password = "thisisnotmypassword";
float h, t, p, pin, dp;
char temperatureFString[6];
char dpString[6];
char humidityString[6];
char pressureString[7];
char pressureInchString[6];
// Web Server on port 80
WiFiServer server(80);
// only runs once on boot
// Initializing serial port for debugging purposes
delay(10);
Wire.begin(D3, D4);
Wire.setClock(100000);
// Connecting to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Starting the web server
server.begin();
Serial.println("Web server running. Waiting for the ESP IP...");
delay(10000);
// Printing the ESP IP address
Serial.println(F("BME280 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
void getWeather() {
h = bme.readHumidity();
t = bme.readTemperature();
t = t*1.8+32.0;
dp = t-0.36*(100.0-h);
p = bme.readPressure()/100.0F;
pin = 0.02953*p;
dtostrf(t, 5, 1, temperatureFString);
dtostrf(h, 5, 1, humidityString);
dtostrf(p, 6, 1, pressureString);
dtostrf(pin, 5, 2, pressureInchString);
dtostrf(dp, 5, 1, dpString);
delay(100);
// runs over and over again
// Listenning for new clients
if (client) {
Serial.println("New client");
// bolean to locate when the http request ends
boolean blank_line = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n' && blank_line) {
getWeather();
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// your actual web page that displays temperature
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head><META HTTP-EQUIV=\"refresh\" CONTENT=\"15\"></head>");
client.println("<body><h1>ESP8266 Weather Web Server</h1>");
client.println("<table border=\"2\" width=\"456\" cellpadding=\"10\"><tbody><tr><td>");
client.println("<h3>Temperature = ");
client.println(temperatureFString);
client.println("°F</h3><h3>Humidity = ");
client.println(humidityString);
client.println("%</h3><h3>Approx. Dew Point = ");
client.println(dpString);
client.println("°F</h3><h3>Pressure = ");
client.println(pressureString);
client.println("hPa (");
client.println(pressureInchString);
client.println("Inch)</h3></td></tr></tbody></table></body></html>");
break;
if (c == '\n') {
// when starts reading a new line
blank_line = true;
else if (c != '\r') {
// when finds a character on the current line
blank_line = false;
// closing the client connection
delay(1);
client.stop();
Serial.println("Client disconnected.");
} I have connected SDA to D3 and SCL to D4 and it just reports that it cannot find the sensor.
Can anyone offer any help please? It would be very much appreciated!
Trev
