#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
const char *ssid = "M3-L7";
const char *password = "Lukas";
ESP8266WebServer server(80);
WiFiUDP Udp;
unsigned int localUdpPort = 8899; // local port to listen on
char incomingPacket[255]; // buffer for incoming packets
char replyPacket[] = "Hi there! Got the message
void handleRoot()
server.send(200, "text/html", "<h1>You are connected</h1>");
delay(1000);
Serial.print("Configuring access point...");
WiFi.softAP(ssid, password);
IPAddress Ip(192, 168, 4, 1);
IPAddress NMask(10,10,100,254);
WiFi.softAPConfig(Ip, Ip, NMask);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
Udp.begin(localUdpPort);
Serial.printf("Now listening at IP %s, UDP port %d\n", WiFi.softAPIP().toString().c_str(), localUdpPort);
server.handleClient();
int packetSize = Udp.parsePacket();
if (packetSize)
// receive incoming UDP packets
Serial.printf("Received %d bytes from %s, port %d\n", packetSize, Udp.remoteIP().toString().c_str(), Udp.remotePort());
int len = Udp.read(incomingPacket, 255);
if (len > 0)
incomingPacket[len] = 0;
Serial.printf("UDP packet contents: %s\n", incomingPacket);
// send back a reply, to the IP address and port we got the packet from
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(replyPacket);
Udp.endPacket();
Serial.println("MAM TO");
