By Theboatbuilder
#74871 findUntil() command crashes my ESP8266 Feather Huzzah
I have used this successfully on an Ethernet Arduino combination without issue.
Moveing to the ESP8266 to do the same but on WiFi crashes the processor.
Here is the subroutine;
void parseJSON()
DEBUG_PRINTLN(F("Parsing JSON"));
String tideTimeStr[7]; // time of each high or low tide as a string
String tideHeightStr[7]; // tide height at this state (not currently used)
String tideStateStr[7]; // tide state at this time
while (client.connected())
if (client.available())
DEBUG_PRINT(F("Client Available"));
if(client.findUntil("station\":\"", '\0'))
DEBUG_PRINTLN(F("findUntil"));
String station = client.readStringUntil('"');
DEBUG_PRINT(F("Station = "));
DEBUG_PRINTLN(station);
for (int i = 0 ; i < 6 ; i++) // 6 tide periods in each API call
{ // Acquire time, height, type (high or low)
if(client.findUntil("dt\":", '\0')) // adding this if statements stops it continuing when all periods are discovered
// Tide time as Epoch time
tideTimeStr[i] = client.readStringUntil(',');
DEBUG_PRINT(F("Tide Period "));
DEBUG_PRINT(i);
DEBUG_PRINT(F(" starting Epoch = "));
tideEpochTime[i] = tideTimeStr[i].toInt(); // convert time string to integer
DEBUG_PRINT(tideEpochTime[i]);
// Tide height
client.findUntil("height\":", '\0');
tideHeightStr[i] = client.readStringUntil(',');
DEBUG_PRINT(F(" Height = "));
tideHeight[i] = tideHeightStr[i].toFloat(); // convert tide height to a float
DEBUG_PRINTDP(tideHeight[i],3);
// Tide type
client.findUntil("type\":\"", '\0');
tideStateStr[i] = client.readStringUntil('"');
tideState[i] = tideStateStr[i].charAt(0);
DEBUG_PRINT(F(" State "));
DEBUG_PRINT(F(" = "));
DEBUG_PRINTLN(tideState[i]);
client.stop();
I hope there is a simple solution.
Many thanks in advance
Mark
