As it sits right now, I have a 2nd ESP-01 that is putting up a single webpage for both the camera and the robot remote control using iframe in a similar websocket sketch, just to test. I would like to get rid of the 2nd ESP-01 and just have the single robot ESP-01 also put up the webcam webpage.
However, whenever I attach an iframe link to the sketch running the robot, I get an error stating certain variables were not declared in this scope. I don't understand how inserting an iframe makes a scope change that way, so I don't know where to attach:
<iframe src="http://192.168.1.6" width="340" height="250" frameborder="1"></iframe>
I've tried inserting all throughout lines 49 to 143 and I get the same errors: all of the "writeMotor****" variables become undeclared.
My hardware is an ESP-01 module controlling an Adafruit V2.3 motor controller and battery pack, sending signals via I2C. The webcam is setting atop a Raspberry Pi with a 5V battery bank, mounted to the tank chassis to put video on IP: 192.168.1.6.
This is the sketch for the Robot, its just a modified Websocket example I have been working on
#include <ESP8266WiFiMulti.h>
#include <WebSocketsServer.h>
#include <Hash.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <Adafruit_MotorShield.h>
#include <Wire.h>
static const char ssid[] = "***************";
static const char password[] = "**************";
MDNSResponder mdns;
int sda = 0; //to pin A4
int scl = 2; //to pin A5
bool FFwdStatus12;
bool LeftStatus13;
bool RightStatus14;
bool ForwardStatus15;
bool ReverseStatus16;
const char Left1[] = "Left1";
const char Forward1[] = "Forward1";
const char FFwd1[] = "FFwd1";
const char Right1[] = "Right1";
const char Stop1[] = "Stop1";
const char Reverse1[] = "Reverse1";
static void writeLED(bool);
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *Motor1 = AFMS.getMotor(1);
Adafruit_DCMotor *Motor2 = AFMS.getMotor(4);
ESP8266WiFiMulti WiFiMulti;
ESP8266WebServer server(80); ////////////82 works online and in LAN//////////////////////////////////////////////
WebSocketsServer webSocket = WebSocketsServer(81); ////////////83 works online and in LAN//////////////////////////////////////////////
///////Open Both of the above ports in the router port Forwarding///////////////////
static const char PROGMEM INDEX_HTML[] = R"rawliteral(
<!DOCTYPE html>
<html>
<head>
<meta name = "viewport" content = "width = device-width, initial-scale = 1.0, maximum-scale = 1.0, user-scalable=0">
<title>RoboSock</title>
<style>
</style>
<script>
var websock;
function start() {
websock = new WebSocket('ws://' + window.location.hostname + ':81/'); ////////////83 works online and in LAN//////////////////////////////////////////////
websock.onopen = function(evt) { console.log('websock open'); };
websock.onclose = function(evt) { console.log('websock close'); };
websock.onerror = function(evt) { console.log(evt); };
websock.onmessage = function(evt) {
console.log(evt);
var e = document.getElementById('FFwdStatus12');
if (evt.data === 'FFwd1') {
e.style.color = 'red';
else if (evt.data === 'FFwd1') {
e.style.color = 'black';
var e = document.getElementById('LeftStatus13');
if (evt.data === 'Left1') {
else if (evt.data === 'Left1') {
var e = document.getElementById('RightStatus14');
if (evt.data === 'Right1') {
else if (evt.data === 'Right1') {
var e = document.getElementById('ForwardStatus15');
if (evt.data === 'Forward1') {
else if (evt.data === 'Forward1') {
var e = document.getElementById('ReverseStatus16');
if (evt.data === 'Reverse1') {
else if (evt.data === 'Reverse1') {
else {
console.log('unknown event');
function buttonclick(e) {
websock.send(e.id);
</script>
</head>
<body onload="javascript:start();">
<center>
<h1></h1>
<p style= "background-color:azure; width:36 0px; border:2px solid black; padding:0px; margin:0px; font-size:24px; color:Green;">
</b>
<button id="FFwd1" type="button" onclick="buttonclick(this);" style="width:150px; height: 50px; font-size: 30px; margin: 10px;">FFwd</button>
<br>
<button id="Forward1" type="button" onclick="buttonclick(this);" style="width:150px; height: 50px; font-size: 30px; margin: 20px;">Forward</button>
<br>
<button id="Left1" type="button" onclick="buttonclick(this);" style="width:85px; height: 70px; font-size: 30px; margin: 18px;">L</button>
<button id="Stop1" type="button" onclick="buttonclick(this);" style="width:85px; height: 70px; font-size: 25px; color: margin: 20px; color: red;">Stop</button>
<button id="Right1" type="button" onclick="buttonclick(this);" style="width:85px; height: 70px; font-size: 30px; margin: 18px;">R</button>
<br>
<button id="Reverse1" type="button" onclick="buttonclick(this);" style="width:150px; height: 50px; font-size: 30px; margin: 20px;">Reverse</button>
</p>
</center>
</body>
</html>
)rawliteral";
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length)
Serial.printf("webSocketEvent(%d, %d, ...)\r\n", num, type);
switch(type) {
case WStype_DISCONNECTED:
Serial.printf("[%u] Disconnected!\r\n", num);
break;
case WStype_CONNECTED:
IPAddress ip = webSocket.remoteIP(num);
Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\r\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// Send the current FFwd status
if (FFwdStatus12) {
webSocket.sendTXT(num, FFwd1, strlen(FFwd1));
else {
webSocket.sendTXT(num, Stop1, strlen(Stop1));
// Send the current Left status
if (LeftStatus13) {
webSocket.sendTXT(num, Left1, strlen(Left1));
else {
// Send the current Right status
if (RightStatus14) {
webSocket.sendTXT(num, Right1, strlen(Right1));
else {
// Send the current Forward status
if (ForwardStatus15) {
webSocket.sendTXT(num, Forward1, strlen(Forward1));
else {
// Send the current Reverse status
if (ReverseStatus16) {
webSocket.sendTXT(num, Reverse1, strlen(Reverse1));
else {
break;
case WStype_TEXT:
Serial.printf("[%u] get Text: %s\r\n", num, payload);
if (strcmp(FFwd1, (const char *)payload) == 0)
writeMotorFFwd(true);
else if (strcmp(Left1, (const char *)payload) == 0)
writeMotorLeft(true);
else if (strcmp(Right1, (const char *)payload) == 0)
writeMotorRight(true);
else if (strcmp(Forward1, (const char *)payload) == 0)
writeMotorForward(true);
else if (strcmp(Reverse1, (const char *)payload) == 0)
writeMotorReverse(true);
else if (strcmp(Stop1, (const char *)payload) == 0)
writeMotorFFwd(false);
writeMotorLeft(false);
writeMotorRight(false);
writeMotorForward(false);
writeMotorReverse(false);
else {
Serial.println("Unknown command");
// send data to all connected clients
webSocket.broadcastTXT(payload, length);
break;
case WStype_BIN:
Serial.printf("[%u] get binary length: %u\r\n", num, length);
hexdump(payload, length);
// echo data back to browser
webSocket.sendBIN(num, payload, length);
break;
default:
Serial.printf("Invalid WStype [%d]\r\n", type);
break;
void handleRoot()
server.send_P(200, "text/html", INDEX_HTML);
void handleNotFound()
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
static void writeMotorFFwd(bool FFwd1)
FFwdStatus12 = FFwd1;
if (FFwd1)
Motor1->run(RELEASE);
Motor2->run(RELEASE);
delay (250);
Motor1->run(FORWARD);
Motor2->run(FORWARD);
Motor1->setSpeed(250);
Motor2->setSpeed(250);
Serial.println("FFwd");
Serial.println("Stop");
static void writeMotorLeft(bool Left1)
LeftStatus13 = Left1;
if (Left1)
delay (250);
Motor2->run(BACKWARD);
Motor1->setSpeed(150);
Motor2->setSpeed(150);
Serial.println("Left");
static void writeMotorRight(bool Right1)
RightStatus14 = Right1;
if (Right1)
delay (250);
Motor1->run(BACKWARD);
Serial.println("Right");
static void writeMotorForward(bool Forward1)
ForwardStatus15 = Forward1;
if (Forward1)
delay (250);
Serial.println("Forward");
static void writeMotorReverse(bool Reverse1)
ReverseStatus16 = Reverse1;
if (Reverse1)
delay (250);
Serial.println("Reverse");
void setup()
Serial.begin(9600);
Serial.println("Websocket Motor Shield");
Wire.begin(sda,scl);
///////////initial settings of the pins on bootup go here//////////////////
AFMS.begin(); // default frequency 1.6KHz
//Serial.setDebugOutput(true);
for(uint8_t t = 4; t > 0; t--) {
Serial.printf("[SETUP] BOOT WAIT %d...\r\n", t);
Serial.flush();
delay(1000);
WiFiMulti.addAP(ssid, password);
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(100);
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
if (mdns.begin("espWebSock", WiFi.localIP())) {
Serial.println("MDNS responder started");
mdns.addService("http", "tcp", 80); ////////////82 works online and in LAN//////////////////////////////////////////////
mdns.addService("ws", "tcp", 81); ////////////83 works online and in LAN//////////////////////////////////////////////
else {
Serial.println("MDNS.begin failed");
Serial.print("Connect to http://espWebSock.local or http://");
server.on("/", handleRoot);
server.onNotFound(handleNotFound);
server.begin();
webSocket.begin();
webSocket.onEvent(webSocketEvent);
void loop()
webSocket.loop();
server.handleClient();
