Page 1 of 5
Problem getting WiFi begining tutorial to work
PostPosted: Mon May 07, 2018 12:12 pm
by SupDoc
This is a tutorial. Code is below. It returns only "square symbol )" in the serial monitor. This code is supposed to deliver:
connecting
"Connected, IP address:"
This is very simple code. It compiles & uploads, Can someone tell how to make it won't work. I put in the correct network name & password.
void setup()
WiFi.begin("network-name", "pass-to-network");
Serial.print("Connecting");
Serial.print("Connected, IP address: ");
void loop() {}
Re: Problem getting WiFi begining tutorial to work
PostPosted: Mon May 07, 2018 1:21 pm
by mgsecord62
I assume you have the serial monitor baud rate set to 115200.
SupDoc wrote:This is a tutorial. Code is below. It returns only "square symbol )" in the serial monitor. This code is supposed to deliver:
connecting
void setup()
void loop() {}
PostPosted: Mon May 07, 2018 2:25 pm
by SupDoc
Yes I have the baud rate @115200. In fact the code in IDE is exactly as indicated in my statement of the problem, except for the network name & password, which I checked 3X to make sure that was right.
Is it possible there could be something wrong with the library version of the ESP8266WiFi.h. I read on a different forum something about a library version, versus a direct version. Regretably, I didn't understand what they were saying.
PostPosted: Mon May 07, 2018 3:25 pm
by cicciocb
Put a delay(0) in the loop function :
void loop() { delay(0); }
