I found a sketch at https://github.com/shariramani/Magic-Sc ... Part-1.ino that does exactly that, but it uses a scroll effect to update the screen, which I want to change to a different effect. Then I found the MD Parola library which has an effect that I want to use (it's called PA_OPENING_CURSOR). As a side note, I am using the latest MD_Parola (https://github.com/MajicDesigns/MD_Parola) and MD_MAX72xx (https://github.com/MajicDesigns/MD_MAX72XX) libraries (they were updated around a month ago).
The result I want to get is:
display the weekday (e.g. Thursday)
switch (with the PA_OPENING_CURSOR effect) to the date (e.g. 12/05/2019)
switch (with the PA_OPENING_CURSOR effect again) to the time (e.g. 19:57)
repeat
By making use of the initial sketch and merging it with the Parola library examples, I've managed to reach to the sketch below (altered from the originals and heavily commented so that I can better understand the code and every step taken - newbie alert) but I've reached to a standstill as I don't know how to pass the required variables to the code that creates the swithcing effect. As you can see, the sketch currently displays the weekday/date/time (Monday/17 Jan 2345/21:59) but their values are only hard-coded (static), so they are not pulled up from the NTP server. The serial monitor of the Arduino IDE shows me that the NTP time is pulled from the NTP server correctly.
The code I have so far is:
NTP CLOCK and DATE Scroller
//___________________________________________________________LIBRARIES USED
#include <MD_Parola.h>
#include <MD_MAX72xx.h>
#include <SPI.h>
#include <WiFiUdp.h>
#include <ESP8266WebServer.h>
#include <TimeLib.h>
//___________________________________________________________PINS DEFINITIONS
#define HARDWARE_TYPE MD_MAX72XX::FC16_HW
#define MAX_DEVICES 8
#define CLK_PIN D5 // or SCK
#define DATA_PIN D7 // or MOSI
#define CS_PIN D4 // or SS
//___________________________________________________________ARBITRARY PINS DEFINITIONS
MD_Parola p = MD_Parola(HARDWARE_TYPE, DATA_PIN, CLK_PIN, CS_PIN, MAX_DEVICES);
//___________________________________________________________USER CONTROL (POTENTIOMETER)
#define USE_UI_CONTROL 0 // set to 1 if we are implementing the user interface pot
#if USE_UI_CONTROL
#define SPEED_IN A0
uint8_t frameDelay = 25; // default frame delay value
#endif
//___________________________________________________________SPEED DEFINITION
#define SPEED_TIME 25 // Lower number means faster speed
#define PAUSE_TIME 2000
//___________________________________________________________DEBUGGING
#define DEBUG 1 // Change to 1/0 to turn on/off debug statements to the serial output
#if DEBUG
#define PRINT(s, x) { Serial.print(F(s)); Serial.print(x); }
#define PRINTS(x) Serial.print(F(x))
#define PRINTX(x) Serial.println(x, HEX)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTX(x)
#endif
//___________________________________________________________WEB SERVER SETUP
ESP8266WebServer server(80);
const char ssid[] = "My_SSID_here"; // your network SSID (name)
const char pass[] = "My_Password_here"; // your network password
//___________________________________________________________NTP SERVER and TIMEZONE
static const char ntpServerName[] = "3.uk.pool.ntp.org";
const float timeZone = 1.0; // UK Standard Time
WiFiUDP Udp;
unsigned int localPort = 8888; // local port to listen for UDP packets
time_t getNtpTime();
void sendNTPpacket(IPAddress &address);
static boolean isLongFormat = false;
String myTime;
String myDate;
//___________________________________________________________TIME AND DATE FUNCTION
void timeDisplay() {
// Populate myTime String
myTime = hour();
if (hour() < 10) {
myTime = "0" + myTime;
if (minute() < 10) {
myTime = myTime + " : 0" + minute();
else {
myTime = myTime + " : " + minute();
myTime = (" " + myTime + " ");
PRINT("\nMyTime: ", myTime);
int myTime_len = myTime.length() + 1;
char myTime_charArray[myTime_len];
myTime.toCharArray(myTime_charArray, myTime_len);
PRINT("\nMyTime_charArray: ", myTime_charArray );
void dateDisplay() {
// Populate myDate String
myDate = myDate + " " + day() + " " + monthShortStr(month()) + " " + year() ;
myDate = (" " + myDate + " ");
PRINT("\nMyDate: " , myDate);
// covert from string/float to char array
int myDate_len = myDate.length() + 1;
char myDate_charArray[myDate_len];
myDate.toCharArray(myDate_charArray, myDate_len);
PRINT("\nMyDate_charArray: ", myDate_charArray);
//___________________________________________________________DEFINE THE TEXT TO DISPLAY
// Global variables
uint8_t curText;
char *pc[] =
"Monday",
"17 Jan 2345",
"21 : 59",
//___________________________________________________________DEFINE THE TEXT EFFECT
uint8_t inFX, outFX;
textEffect_t effect[] =
PA_OPENING_CURSOR,
//___________________________________________________________USER CONTROL ACTIONS (IF USED)
#if USE_UI_CONTROL
void doUI(void)
// set the speed if it has changed
int16_t speed = map(analogRead(SPEED_IN), 0, 1023, 0, 250);
if (speed != (int16_t)p.getSpeed())
p.setSpeed(speed);
p.setPause(speed);
frameDelay = speed;
PRINT("\nChanged speed to ", p.getSpeed());
#endif // USE_UI_CONTROL
//___________________________________________________________void setup
void setup()
p.begin();
#if DEBUG
delay(1000);
#endif
PRINTS("\nLet's see if this thing will EVER work...");
PRINTS("\n ");
delay(1000);
PRINT("\nConnecting to the WiFi Network named > ", ssid);
WiFi.begin(ssid, pass);
delay(1000);
PRINTS("\n ");
PRINTS("\nConnection established successfully");
PRINTS("\n ");
PRINT("\nThe IP address assigned to your device by your WiFi router is ", WiFi.localIP());
PRINTS("\n ");
PRINTS("\nStarting UDP...");
PRINTS("\n ");
Udp.begin(localPort);
PRINT("\nLocal port: ", Udp.localPort());
PRINTS("\n ");
PRINTS("\nWaiting for synchronisation...");
PRINTS("\n ");
PRINTS("\n ");
setSyncProvider(getNtpTime);
setSyncInterval(120); // NTP re-sync interval in seconds
#if USE_UI_CONTROL
pinMode(SPEED_IN, INPUT);
doUI();
p.begin();
p.setInvert(false);
p.displayText(pc[curText], PA_CENTER, SPEED_TIME, PAUSE_TIME, effect[inFX], effect[outFX]);
//___________________________________________________________NTP CODE
const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packets
time_t getNtpTime()
IPAddress ntpServerIP; // NTP server's ip address
while (Udp.parsePacket() > 0) ; // discard any previously received packets
Serial.println("Transmited request to the NTP server:");
WiFi.hostByName(ntpServerName, ntpServerIP);
Serial.print(" "); Serial.print(ntpServerName);
Serial.print(": ");
Serial.println(ntpServerIP);
sendNTPpacket(ntpServerIP);
uint32_t beginWait = millis();
while (millis() - beginWait < 1500) {
int size = Udp.parsePacket();
if (size >= NTP_PACKET_SIZE) {
Serial.println(" ");
Serial.println("The NTP server responded successfully");
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the buffer
unsigned long secsSince1900;
// convert four bytes starting at location 40 to a long integer
secsSince1900 = (unsigned long)packetBuffer[40] << 24;
secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
secsSince1900 |= (unsigned long)packetBuffer[43];
return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
Serial.println("No NTP Response :-(");
return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 30; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
//___________________________________________________________void loop
void loop()
#if DEBUG
#define PRINTD(x) Serial.println(x, DEC)
#else
#define PRINT(s, x)
#define PRINTS(x)
#define PRINTD(x)
#endif
#if USE_UI_CONTROL
doUI();
if (p.displayAnimate()) // animates and returns true when an animation is completed
// Set the display for the next string.
curText = (++curText) % ARRAY_SIZE(pc);
p.setTextBuffer(pc[curText]);
// When we have gone back to the first string, set a new exit effect
// and when we have done all those set a new entry effect.
if (curText == 0)
outFX = (++outFX) % ARRAY_SIZE(effect);
if (outFX == 0)
p.setTextEffect(effect[inFX], effect[outFX]);
// Tell Parola we have a new animation
p.displayReset();
}Could you please guide me on how to achieve this? I am completely new to Arduino programming and this is already way too complex for me. I understand that I am very close to achieving what I want but I can't figure it out with my very limited knowledge.
Thanks in advance.
